Question about RCA Televison & Video
I have RCA output/input. Does anyone make an automatic switched timer for these inputs?
I would prefer to have the TV turn on with a timer but it appears this is not practical. If I power down the receiver it takes forever to power up. There must be some way to put the RCA cables on some kind of timer and just turn off and on the input to TV?
    Master:
  • 742 Answers
No, just turn the tv off...........
Posted on Dec 03, 2014
Testimonial: "While I would like to be be able to thank you for your response...I have found an actual remedy thanks to another helpful person."
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
How to hook it up to new emerson tv without s-viedo connection
Hi,here is my solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
If you want to display your DVD on the TV,than do everything visa versa..as;
**connect "Video Output " RCA jacks or "Optic cable output" of your Receiver
** to "Video input " or "Optic Cable input"
of your TV and make a selection corresponding input of TV
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up to continue f
or Helping out the Community :)
Apr 10, 2011 | Curtis DVD6041 System
Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
Hello!
I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
Here's what you need to do:
1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
  • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
  • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
  • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
  • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
  • HDMI >>>>> HDMI
5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
Hope this helps!
Mar 14, 2011 | Televison & Video
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
61 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
