Question about Home
I have a model 4012001, chrome, Oakbrook shower faucet. it has the crystal hand knob....is a lever handle conversion available?
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
  • 81 Answers
SOURCE: pulsating water and poor hot water pressure
Based on your description it sounds like the pressure balancing valve could be gunked up with particulate from your well or just worn out. If your water is not filtered to that shower I would lean more towards particulate. Try to remove the cartridge and take it to a plumbing parts store for a match-up since Delta makes several cartridges and you want to get it right the first time.
Posted on May 29, 2010
  • 4340 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
How to remove cartridge from oakbrook shower faucet with 3 handles
You take off the handles, then the packing nut and you should see the valve stem and it unscrews all the way out. You can then look at the seal on the steam and the seat is in the valve. To change the seat, you need a special tool that fits in the fixture to twist the seat out.
Jun 12, 2015 | Ace Hardware OakBrook& Three Handle Tub...
Aqua source single handle shower faucet and no set screw so how does the handle come off
If the handle is a "knob" style handle, then there is a "not easy to detect" decorative thin circular plate that inserts into the center of the knob (Its usually about 3/4" to 1 1/2" in diameter)
Examine closely and feel for an edge or separation between the insert and main knob body. Pop it out with a thin-edged screwdriver or such.
If it is a lever type, there's usually a setscrew in a hard to see area behind the lever, where it meets with the faucet cartridge.
Oct 30, 2014 | Home
How do you tighten the shower turn on handle?
If it is a lever handle, there is an allen key set screw on the under side of the handle hub. IIf it is a knob handle. remove the plastic cap at the center of handle and tighten the phillips screw.
Jul 16, 2014 | Delta & Single Handle Shower Faucet
System won't switch to shower
You need a diverter in your spout. The spout will screw off and the new one will screw on. Lift the ball while the water is running and it will divert the water to the shower.
Dec 14, 2012 | American Standard One Handle Tub & Shower...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
What size screw goes in the tub and shower chrome faucet set
Well Ace has these faucet made for them buy numerous manufactures and knowing which company made this one it hard to say. I would go to Ace and have them investigate this for you. Sorry but there is just to many variables here to be able to give a defiant answer to this question.
Feb 06, 2011 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
How do I remove knob from Hansgrohe shower faucet? Need to remove to repair drip/replace washers.
Depends on the model, there's usually an allen screw holding the knob on, this can be hid under a little chrome cover or under an unscrewable lever.
Apr 10, 2010 | Home
Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
