HELLO. My oki c9600 gives me an error code 145. I Allready replaced the magenta id unit But the error is still on. Can somebody give me a hint? Regards from germany
    Master:
  • 149 Answers
Was ist los, Kamerad?
An error was detected with the magenta toner supply mechanism sensor; if rebooting the machine does not improve the symptom, you need to check the device. This does not necessarily mean that the toner cartridge is defective nor empty but that its sensor is not detecting it. Use a clean, dry Q-Tip (cotton swab on a stick) to clear toner dust from the gold contacts.
Posted on Dec 03, 2014
  • 1 more comment
  • Dom Indy
    Dom Indy Dec 10, 2014
    Hi. Thanks for the answer. :-) i cleaned all contacts that i have found on the id unit and on the Toner cartridge But the error is still there. I am a elektrical technician so I can also Check the inner Parts of the machine if somebody can tell me where i have to look. Is it possible that These error apeare if something is Wrong whith the rfid Sensor? ? Regards indy
  • Points To Ponder Dec 11, 2014
    Turn on this printer while holding [+] & [-] & [help] buttons until the “OKIUSER” message appears in the LCD display. Press either [+] or [–] until “ENGINE DIAG MODE” displays. Then press [ENTER], & the display will show "DIAGNOSTIC MODE XX.XX.XX S-MODE." Press either [+] or [–] until “NV-RAM INITIAL” displays. Press [ENTER], again, to display the "TABLE 1" message. Press [ENTER] until the "EXECUTING RESET" message appears. Then, the "NV-RAM INITIAL" message will BLINK. This procedure resets the drum, the fuser, & the belt. Turn the printer off for about ten seconds before turning it back on.
  • Dom Indy
    Dom Indy Dec 11, 2014
    YES!! :-) :-) IT WORKS ! THANKS!!!
  • 78 Answers
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
SOURCE: Oki c9600 printer - waste toner box
Sometime the white round spring action mechanism on the printer breaks which causes the toner box warning This mechanism connect to the printer toner box when installed.
Posted on Aug 10, 2009
  • 97 Answers
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
Bizhubman
  • 108 Answers
SOURCE: machine gives me C-2251 error code after replacing
If the drum units have been in storage too long they will bind up a little.
Lightly tap the drum unit on the ground. Look on the back of the drum unit and locate a white cam gear. Take a pair of pliers an rotate this gear until it moves more freely.
Posted on May 22, 2010
  • 567 Answers
SOURCE: hello good day printer is saying
Hi please uninstall the drivers for the printer and reinstall them again,then restart the computer and see if the error still exist.
Please let me know if you have any questions
Posted on Jul 17, 2010
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
Error 360 oky c9600
you open the drum unit on top and look on the side cover
find out the fuse (green color fuse)
you just replace it by clipping it in and done.
vote me if found helpful.
Aug 04, 2011 | OKI C9600hdn Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Have a oki c9800 ...gives error 923. have replaced the motor unit for black image drum but it prints some pages and gives the error again
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Dec 10, 2009 | OKI C9600hdn Laser Printer
Oki c9600 fatal error 175 ?
Error 175
Fuser Thermistor
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
again.
Dec 06, 2009 | OKI C9600n Led Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
141: fatal error OKI Printer
This can be caused by the transfer belt damage or the contact group damage. 141 is an error of Magenta ID up/down. Possible reason though - check the place next to the belt at the right hand side near the Magenta drum location. You'll see the terminals sitting in the housing with the spring. If the housing is fell off or the spring is missing - that can cause this error. Otherways you'll need to replace the transfer belt.
Jul 30, 2009 | OKI C7300 Led Printer
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Office Equipment & Supplies
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
97 people viewed this question
k24674
