Question about SEIKI Digital SE40FY19 40" LED TV 1920x1080, 60 Hz, HDTV
How do i change country setting - SEIKI Digital SE40FY19 40" LED TV 1920x1080, 60 Hz, HDTV
    Master:
  • 742 Answers
Depends on what you mean, you can not usea NTSC set on PAL broadcast. Or vice versa. The signals are not compatible
Posted on Dec 03, 2014
How to change the country setting on sharp aquos?
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 07, 2016 | Sharp Aquos Televison & Video
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Can't Change Country Setting
What is the system of transmission to German transmissions? Is it PAL? If so, you can set its country code option, by entering its service mode option. In this option, you will get a section to change its country option. If the Samsung model TV of yours' have facility to receive German transmission, check this mode. For more information go to http://electronicshelponline.blogspot.com/
Dec 19, 2013 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Change the country setting for a garmin 1350
Typically, when the unit is turned on, the satellitetechnology is able to pin point the unit's current location and provide mapsbased on the user's position. However, if there is not a clear signal or youare located in a different country than the ending destination you are tryingto program into the unit, you may have to manually change the country. For thatplease follow these steps: 1. Touch anywhere on the display screen to access the mainmenu. 2. Tap or select the "Change Preferences" options. 3. Navigate to your map settings. In a Garmin this will belocated under the "View Maps" and then "Change Maps"settings. 4. Use the "Up" and "Down" arrows toscroll through the list of available countries. Once the country you arelooking for is highlighted, press the "OK" button. You will then beasked to select a state or more specific region in the selected country. Onceselected, press "OK" second time. Hope this will help you. Good Luck.
Aug 16, 2011 | Garmin Nuvi 660 GPS Receiver
How do I set Canandian addresses
You don't say where you are. I'm presuming that you're in the USA and have a map of Canada on your satnav. If so press WHERE TO and then ADDRESS. When you press address the country it's set to is shown at the top of the screen. At the bottom there's a bar which says CHANGE COUNTRY (if you have a second country on your map) Press CHANGE COUNTRY and type CANADA. You should then be able to set Canadian addresses.
Aug 03, 2011 | Garmin nuvi 205W GPS Receiver
How do I change countries in Europe
  • Press WHERE TO
  • Press ADDRESS
  • At the top of the screen you'll see the name of the country the satnav is set to. At the bottom of the screen you'll see an icon CHANGE COUNTRY
  • Press CHANGE COUNTRY and enter the new one
Jul 19, 2011 | Garmin nuvi 205W GPS Receiver
HP psc2175 printer accidentally had it's languae changed from english to some other language. When turned on it says "1 Kopie /100%. How do I change it back?
I was able to find this at te hp website:
set the language and country/region
Usually, the language and country or region are set when you install the
HP PSC. If you set the country/region or language incorrectly during
installation, use the following procedure.
1 Press Setup.
2 Press 2, then press 4.
This selects Maintenance, and then selects Set Language & Country/
Region.
You are prompted with a list of languages. You can also scroll through the
languages using or .
3 Using the keypad, enter the two-digit number for the desired language.
4 When prompted, press Enter for Yes or Cancel for No.
You are prompted with all the countries/regions for the selected
language. You can also scroll through the countries/regions using or
5 Using the keypad, enter the two-digit number for the desired country/
region.
6 When prompted, press Enter for Yes or Cancel for No.
7 You can confirm the language and country/region by printing a Self-Test
Report, as follows:
a. Press Setup.
b. Press 1, then press 2.
This selects Print Report, and then selects Self-Test Report.
Apr 20, 2011 | HP PSC 2175 All-In-One InkJet Printer
We have a samsung sr150m digital DVD recorder with the country code set to austria, and so will not work, how do we change country setting. Hope someone can help. Thanks
If you bought it in a country not in austria, there must be a feature in it that you can change the country code setting. Try to go to the menu or set up on the remote control or the buttons on the unit. Scan for the features using the arrows. If you find 'country code settings', change it to the country you prefer.
Oct 03, 2010 | Samsung Televison & Video
Can`t change mms settings since I changed countries
DEAR FRIEND,
YOU CAN GO TO MENU, MENU TO SETTINGS, SETTINGS TO CONNECTIONS, CONNECTIONS TO CONNECTION SETUP. HERE U CAN GET ANY SETTING OF ANY COUNTRY OR NETWORK SETTINGS.
ALWAYS CONFIGURE YOUR INTERNET SETTINGS FROM CONNECTION SETUP. THEN U WILL NEVER GET ANY PROBLEM NEXT TIME.
THANKS ALOT,
SANJEEV KUMAR
Jan 21, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
SEIKI Digital SE40FY19 40" LED TV 1920x1080, 60 Hz, HDTV Logo
229 people viewed this question
Top SEIKI Digital Televison & Video Experts
richie46
 Mikey
Mikey
Are you a SEIKI Digital Televison and Video Expert? Answer questions, earn points and help others
