Question about In Microwave Ovens
I have a Moffat 3000 Gas Oven and grill and need to replace the leaf spring in the oven door handle - I can't find any details on exact shape or length, although I have the broken stem which screws on
I've removed the handle from the door and diagnosed the problem - I need to replace the broken leaf spring to fix it. As I only have part of the leaf spring I can't tell the exact length and shape, e.g., curved, angled etc.
    Top Expert:
  • In Master
  • 44,414 Answers
Contact the MFG either thru their website or phone
Posted on Mar 14, 2015
jfpogie
  • 104 Answers
SOURCE: I can't remove the door handle.
thanks
Posted on Feb 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Posted on Feb 02, 2009
milten1
  • 1304 Answers
SOURCE: Problem: How can I replace the door handle on a
ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
Posted on Oct 10, 2009
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
Replace door
If you're replacing the entire door, this is a very simple process that only requires you to open the door all the way and lift straight up at the hinges. The door lifts off the hinge pins, and the new one can be reinstalled by aligning it back on the hinge pins. (You may have to remove the hinges from the old door and install them on the new one on some models). NOTE: In some cases you may have remove the upper grille guard to accommodate lifting the door. The mounting screws for the guard on located across the top of the oven. If you only need to replace the door handle, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 26, 2011 | GE Spacemaker JVM1540 Microwave Oven
I NEED DIRECTIONS TO REPLACE THE DOOR HANDLE ON MY MICROWAVE OVEN, PLEASE
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. If you haven't purchased a new handle yet, the part number is 8184264.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
May 11, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The door handle on the microwave oven has broke, How do I replace it I have a replacement handle
Dec 22, 2010 | Microwave Ovens
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace door?
If the model number is correct, the door on the microwave comes off by opening it all the way and lifting straight up at the hinges. The entire door will lift off the hinge pins and come off. You may have to remove the upper grill cover above the door to accommodate removing.
If this is a simple matter of just needing to replace the door handle, or broken panels, you can save money by replacing only the parts you need. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements (if required) may be purchased at the websites listed in the link I provided.
The door handle, or other miscellaneous parts are usually simple repairs that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
What I have provided you with is the basic information that applies to most ovens. If you have any questions, please post back and let me know. I hope this helps you.
Apr 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
