Question about Intermatic Hardware & Accessories
Intermatic HB35R timer has its current time correctly set with both on and off trippers also set correctly.....Tier will not come on @16:30 as programmed......Have to use manual switch to turn on and then turn off @ 23:00....What am I forgetting to do here?....Thanks...
  • 3,287 Answers
Place green tripper at ON time & red tripper at OFF time. Twist timer dial one or more times until current time of day is aligned on pointer. When twisting timer, the trippers should actuate the manual knob on and off each time you make a full turn. Make sure trippers are fully inserted so that they engage the "catch" of the override knob - if not they will not cycle power to the output.
Posted on Dec 03, 2014
I have unscrewed my tier pointer by mistake to coincide with the current time on my T21004R timer. Now I cannot get into start and turn off where my on and off indicators are set. How do I correct thi
T21004R is single 240Volt T104M mechanism inside a 60 amp control panel.
The T100 series timer has stationary pointer that is supposed to be straight downward. Move pointer into downward position and apply bit of super glue to hold in place, or just remember where it should point.
Copy following links for instructions how to set and use the T104 timer.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
The T104 timer is rated for 40 amps, and is usually repairable, uses WG1573 replacement clock motor, and 156T1978A trippers. Trippers are made of softer metal and are designed to wear out before wearing down timer mechanism.
Jul 20, 2012 | Intermatic T21004R- Pool-Spa Mechanical...
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
Aug 09, 2011 | Solar Intermaticlamp & Appliance Timer...
HOW SET TIME ON AND OFF
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Rotate dial around until current time lines up with mark
Dial rotates with passing time.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
How to set on at 4 pm and off at 7am
How to set timer.
In this case, set silver ON tripper at 4pm
Set brass OFF tripper at 7am
Timer comes with 2 pair of trippers, so you will only use one pair.
Save the extra pair of trippers for when 1st pair of trippers wears out.
Manually rotate dial around to watch lights come on.
To set current time, rotate dial until current time lines up with mark.
Manual E-1020
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
Nov 20, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Set the clock for current time, but lights come on 3 hours before the on tripper.
You posted under T103 Intermatic timer
Add a comment if you have different brand.
Current time lines up with silver pointer.
Sounds like silver pointer is not at 6:00 position
Review timer operation:
T-103 timer dial rotates around until tripper contacts mechanical lever:
On tripper pushes lever one direction until it clicks, OFF tripper pushes lever other direction.
Each time lever clicks into position, manual-override lever also moves back and forth.
Manual override is connected to same lever that trippers push.
Troubleshoot:
Watch if timer functions as described above.
Click manual override and check that lights turn on-off correctly.
Add a comment if timer is doing something other than described.
Nov 16, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
If I understand correctly, you have an Intermatic timer.
The timer has a yellow dial that rotates around like a clock.
Does the manual override work?
If yes.
a) then the circuit has electricity
b) the lights are in working order
Does the clock rotate?
If yes
a) then the timer is probably good
b) the clock motor could be bad
c) the gears could be rusty and dirty
Do you have the current time set correctly?
Lift and rotate dial until current time lines up with silver pointer.
Do you have the trippers set on the correct time?
There are ON trippers and OFF trippers
Attach trippers to correct time
Tripper pins wear out
Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
When the trippers get to the bottom, they push a lever that turns lights on and off.
Look at the photo:
Here's a website that sells tripper pins and clock motors for Intermatic timers.
You can buy new trippers or clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Answer this post if you still can't figure out the problem, or need more help.
Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do i set timer to turn lights off and on
If I understand correctly, you have Intermatic electro-mechanical timer that has a yellow clock dial on front
And you want to set the timer to turn lights on and off
And your wiring is correct and the manual override turns the lights on-and-off correctly
To set timer:
Pull dial back toward you. Rotate clock dial until current time lines up with silver pointer.
On other brands of timer, you rotate dial until current time lines up with an arrow or the word 'time' located on lower right of clock dial
Timer has on-off trippers that fit outer edge of dial.
Intermatic trippers are labeled ON and OFF
Other brands of timer have dark and light-colored trippers >> I think the dark trippers on some brands are OFF
Place 'off' tripper when you want timer to turn off
Place 'on' tripper when you want timer to turn on
Turn on electricity and expect timer to run for 20 years
Dial has to be re-set to current time after power outage
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Oct 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
78 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
