Question about Bissell 3522 PowerForce Bagged Upright Vacuum
My bissell powerforce keeps clogging
I have cleaned out the hose
  • 1,511 Answers
Have you checked the internal filtration system?
Posted on Dec 02, 2014
My bissell power force bagless model 6594-w vaccuum is not sucking up when vaccuuming but if i use the hose it works
Remove the bottom plate that covers the brush assembly and check the air passage that goes out where the vacuum is jointed between the vertical parts and the sweeper head. Look for any clog in that area. A bent hook on the end of a piece of coat hanger wire is a good tool for cleaning clogs. Hope this helps!
Dec 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell Powerforce Turbo is blowing dirt instead of sucking it up! Canister and filters are clean. Help???
there might be a clog down in the nozzle hose or in your main attachment hose. check for suction.
Jan 03, 2010 | Vacuums
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Re: model 3522-5 Bissell proforce bagged vacuum hoses clogged
Worked perfectly. Thanks, jade_greeney. We thought we were going to have to shell out $100+ for a new vacuum.
Jul 03, 2009 | Bissell 3522 PowerForce Bagged Upright...
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum Does Not Have any Suction
it could be clogged somewhere inside the hose. try unclogging it with a thin pole or rod.
Mar 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless upright vacuum 6582
Check your filter. Sounds like it is not receiving enough suction to pull up the debris. If your filters are clean and there are no clogs, disconnect hose from back by the tank and see if you have suction straight out of the whole.
Dec 11, 2008 | Bissell Vacuums
Dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
May 30, 2007 | Bissell 3522 PowerForce Bagged Upright...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
