Items you can buy separately on a menu or of fare is called
How do I estimate the cost of a fare by Uber?
Call the closest UBER and they will give you the exact fare.
Aug 23, 2017 | The Computers & Internet
No signals on any inputs. Menu items appear on screen correctly.
I suspect you have a failed main power supply, this model may not be well-protected against brownouts or surges.
The main supply is usually a separate board and if you remove the lower rear panel, look for a board that seems to be related to the AC line and has larger components than the other boards. Some of them will be cylindrical and others block-like.
Look for a board number since this is a component that is often outsourced and may not be from the same manufacturer in every set. Call the nearest service center to inquire about repair or replacement costs
Jun 20, 2011 | Mitsubishi WD-52725 52". Rear Projection...
It tells me I have insufficiant memory storage I have deleted txt messages ringtones drafts etc. I have a memory card but it just holds my pictures. It has made me stop recieving text messages and is...
I had the same problem so I called AT&T and they solved the problem!!
1. Click 'Start'
2. Click 'Messaging'
3. Click 'Messages'
You should be in the screen where it shows all your text messages, not just one. If not, click the 'go back' key until you see the list of all your text messages.
4. Click 'Menu'
5. Choose 'Folders'
Your screen should be showing Deleted Items, Drafts, Inbox, Outbox and Sent Items folders.
6. Click 'Drafts' folder
7. Click 'Menu'
8. Choose 'Delete All'
After it has finished deleting, your screen should say To create a new message, etc.....
9. Click 'Menu' again
10. Choose 'Folders' again
11. Click 'Inbox'
12. Click 'Menu'
13. Choose 'Delete All' When its finished deleting it should say 'To create a new message, etc.....'
14. Repeat steps 9-13 for the Outbox and Sent Items folders as well.
15. Once you are SURE you have deleted all your messages in all the folders, click 'Menu', choose 'Folders', and choose the 'Deleted Items' folder
16. Once in the 'Deleted Items' folder, click 'Menu' and choose 'Delete All'
Since the Propel Pro is run by Windows, it's kind of like emptying the Recycle Bin on a computer. You delete the items and they go to a 'Deleted Items' folder, where you can 'Delete All' of the deleted items. I know it sounds confusing, but that is how you can get your 'Free Storage' back.
Once you've deleted your deleted items, (LoL) you can check your 'free storage' by going to "Settings" .. "More" .. "Memory Info" and the "Storage" (middle/orange folder) should have significantly gone down! I went from 89MB to 17MB!!
I really really hope this helps! Good Luck!!
If you still have storage problems, call 1-800-331-0500 and Dial 0 for customer service then dial 1 for technical support. They should be able to help you step by step! I really hope this helped! Good Luck again!!
-Denise
Sep 04, 2010 | Samsung Propel Pro SGH-i627 Cell Phone
Rode NTK power supply and cable needed . I inherited a mic but no power supply or cable.
use the web dude
http://www.rodemic.com/support.php#q23
Q: Can I buy a power supply for my mic?
A: NTK, K2 & Classic II mics are sold as complete units, power supplies and mics are not sold separately but as warranty items only.
For direct information and technical support questions contact:
In Australia:
ozsupport@rodemic.com
or call (02) 9648 5855
In United States and Puerto Rico:
usasupport@rodemic.com
or call (805) 566 7777
between 12:30PM and 4:00PM PST
Hope this helps
Thanks for using FixYa
Aug 12, 2010 | Rode NTK Professional Microphone
Do you get a new drum with a toner replacement cartidge or is it a separate thing you have to buy
Hello.
The drum and toner cartridge are separate items. Both are replaced by the user.
The toner cartridge holds toner/ink. The drum does the work. You will need to replace the drum for every 4-5 toner cartridges used.
I've seen toner cartridges for your printer at $36 vs $60 for a drum.
Hope this helps.
Jun 13, 2010 | Brother MFC-7440N Laser Printer
With a new Minnkota Endura for the grankids, I'm looking for extension wiring to the battery in front of the mid seat of a 14' flatbottom, and the 60 A fuse holder. Does the company sell these items?JIM
you can buy a universal extension set from a boat supply store and some autopart stores. the fuse and holder would have to be installed separately. sometimes this is not recommended by some manufacturers though.make sure you use the proper guage wiring to prevent the wiring from heating up. also call the 800 number on the motor to see if the company offers a manufacturer approved kit. good luck.
May 27, 2010 | Minn Kota Boating
External calling rings
I have no idea how it was fixed! I redid some of the menu items to ensure that nothing had been deleted; it is working fine now! Thanks for the support!
Jun 01, 2009 | Olympia OL2410 Cordless Phone
Menu Reconfiguration Problem
The menu items on my 2600 have changed to email (1) messaging (2) recent calls (3) media net (4) media mall (5), etc....I cannot find the alarm features, not even in the games & applications menu item. What probably happened? How do I get my 2600 to give me the standard menu item
Oct 29, 2008 | Nokia 2600
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
