Who will repair answering machine 1337 It has a humming sound.
IT HAS A HUMMING SOUND
    Sergeant:
  • 271 Answers
USUALLY A HUMMING SOUND WILL BE FROM THE CIRCUIT BOARD OR A SMALL CAPACITOR WHICH ELIMINATES ALTERNATING CURRENT HUM. HONESTLY SPEAKING, I THINK A NEW PHONE IS IN YOUR FUTURE.
Posted on Dec 02, 2014
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
  • 6 Answers
SOURCE: series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Posted on Jan 14, 2008
  • 1314 Answers
SOURCE: Samsung b1445 washer
let me do a little research can you turn the drum by hand to make sure nothing is jamming it
Posted on Feb 16, 2008
  • 96 Answers
SOURCE: beko 520w wasing machine
Humming sound at start usually means a door lock problem. Check that the door is actually locking.
Posted on Mar 10, 2008
SOURCE: Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Posted on Nov 02, 2008
My electrolux washing machine displayed E1 error and no water will go in? what to do with this?
Is the pump making a humming sound? If you can answer yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you may have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue?
Jan 25, 2017 | Electrolux Washing Machines
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
I have asked my question twice It has not been answered yet WHY?
Hard call without seeing the failure.
No hot water? Does the heating light come on? If so, then the element is gone. Not economical to replace it.
Humming sound? What frequency? Is it a pump that runs continuously? If a tube is broke, it might be repairable. A bad pressure sensor will not be.
If the sound is a 60 cycle low hum you may have an electrical failure and possibly a dangerous machine. A wiring problem has a small possibility of repair.
Apr 25, 2014 | Keurig Elite B40 Coffee Maker
When we answer the phone their is a humming sound,when you put it on speaker it gets louder
This could be due to hum on the line rather than a problem with your phone. If you can connect another phone to your line and hear the hum, the problem is with the line. Also, in some areas line hum comes and goes depending upon weather and other factors
Feb 03, 2013 | Panasonic KX-TG7645M Cordless Phone - DECT...
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
When i start my Indesit washing machine,i hear a humming sound
sounds like the drive collar is broken between the motor and transmission shaft its really not that hard to replace however if you have never repaired one then you really should get a service tech to do it
Jan 13, 2010 | Washing Machines
MECHINE MAKES HUMMING SOUND, IT WON'T SPIN, WON'T
THe motor coupling or belt is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 08, 2009 | Kenmore Washing Machines
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Humming noise
in line filter, they sell them at Fry's.com or radio shack
Oct 29, 2007 | Lands Phones
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
