Question about Sewing Machines
Broke the needle holder with a side attachment. The one ordered was a front view attaching where can I find the side oe
  • Sewing Machines Master
  • 1,860 Answers
Try this link Choose Your Brand
Posted on Dec 03, 2014
The new needle will not go into the holder I have the flat side facing away from me.
Sounds like the screw that holds the needle in place is tightened so there is no room for the needle to fit. Loosen it and try installing the needle. Some machine needle clamps will move around when loosened. Just gently pull it back where it should be.
Feb 27, 2018 | Sewing Machines
How to put back the part where the needle is attached?
youtube has good videos. Check this link, you will probably be able to see how the part is attached. Brother XL 6562 YouTube
Jul 31, 2014 | Brother XL-6562 Mechanical Sewing Machine
I am sewing leather with bernina. Got proper leather middle but the needle either gets stuck or falls out. Why and what should I get that I can work with heavy leather ( FYI I am not working with heavy at...
check the needle holder if its tight enough not to fall out. now if your needle gets stuck, try using another needle appropriate for your material. if your problem persists, the problem might be on how do you attach your needle. try attaching in reverse side.
Jul 14, 2014 | Sewing Machines
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
How do I attach the darning foot on a Pfaff Expressions 2.0 please?
on the machine, there is a foot holder attached to the machine, & the feet to the machine will either be snapped on to the foot holder or there is a screw to undo. most of the new machine are snap on feet, take the presser bar lever up, there is a little lever on the back of the foot holder, & you push it toward the foot holder bar & it will release the foot & you put the other foot down on the needle plate & bring the foot holder bar down on the foot until it snaps on to the foot
May 04, 2012 | Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
My needle broke and I tried changing it, but don't remember if the pine hole goes in the front or the side. I have changed it both ways but still not sewing right. I don't have a manual. I am sorry my...
hi there
if you want user manual please go to www.juki.com under industerial sewing machine you can download instruction manual. concern how to attach needle i tell you ther is to saide long groove must be at ur left hand not front or rear and please remember any machine from which said u threading u must attach the needle with long groove in the same said u threading the machine.
best regards
ashraf abozid
aabozid@hotmail.com
Jun 12, 2010 | Juki DDL-8700
Needle broke of and I think it went into the bobbin area. Now I think that the timing is off . I have a bernina 180.
Have you removed the broken pieces? The bobbin holder snaps out with 2 side holders to remove broken needle pieces. I don't think that the timing can get off by a broken needle. My first original bobbin holder got damaged which was made of hard plastic, from embroidering, and I ordered a stainless steel model which is available from a Bernina dealer, and all works very well for the last 2 years, there was never any problem.
Feb 12, 2010 | Bernina Artista 180
Changing needle
flat side of needle is away from you when entering the needle holder then tighten (be sure machine is facing you and flat side of needle is on the opposite side)
Jan 14, 2008 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
