Question about Kenmore Series 70 Washer Motor 387780
How to remove the timer? - Kenmore Series 70 Washer Motor 387780
    Sergeant:
  • 271 Answers
HERE IS A LINK TO YOUTUBE VIDEOS CONCERNING YOUR WASHER..... BUT I DIDNT SEE ANYTHING ABOUT A TIMER. I HAVE REPLACED KENMORE TIMERS....PULL OFF THE KNOB...
REMOVE THE SCREWS THAT HOLD DOWN THE COVER WHERE THE TIMER IS LOCATED.... ONCE YOU HAVE THE COVER OFF..... GET YOUR PHONE OR CAMERA AND TAKE A PICTURE OF WHERE ALL THE DIFFERENT COLORED WIRES ARE LOCATED...SO YOU WONT BE LOST WHEN YOU INSTALL THE NEW TIMER.
https://www.youtube.com/results?search_query=HOW+TO+REMOVE+A+TIMER+Kenmore+Series+70+Washer+Motor+387780
Posted on Dec 02, 2014
How do i remove an evebt
Usually timer programs can be edited by entering the program mode and scrolling through choices....
Some timers do not allow you to remove a program... and you have to reset timer and reprogram to completely remove program
ST01 timer has step-by-step for deleting program on page 2 of manual ... on right side of page... under changing program times... deleting ON-OFF setting
http://waterheatertimer.org/pdf/Intermatic-st01c.pdf
http://waterheatertimer.org/ST01C-program.html
Gene
Water Heater Timers Save Money
Jun 02, 2014 | Intermatic & Self-Adjusting Wall Switch...
Tip
How to Replace a Defrost Timer in a refrigerator?
What is timer?
Timer is a small motorized unit that controls the function of defrosts cycle in a refrigerator. The defrost timer tells the refrigerator when to cool and when to defrost any ice frost collected on/in the evaporator coil.
Now the procedure to replace the timer is as follows:--
1) First of all for proper safety please unplug the unit from power outlet.
2) Then to locate the timer. It is located behind the refrigerator beside the compressor of the refrigerator. You will have to remove the metal kick plate on the bottom of the refrigerator. In older models refrigerator it is built into the icemaker unit.
3) In some models timer is fitted by the screws on the side wall of the refrigerator unit. so if screws are seen remove the screws holding the timer to the refrigerator wall.
4) Then slowly/carefully remove the timer out of the unit so you can disconnect the wiring from the connectors. For easy access of connectors try wiggling the connectors back and forth it will be disconnected.
5) Before removing the connectors please take a note of which connector was connected where and in what position.
6) Then take a new timer and plug the connectors in same position and at same spot in the new timer.
7) The refit the screws if you removed while removing the old defrost timer, replace the kick plate cover and plug in refrigerator and check out.
This will help. Thanks.
on Mar 10, 2010 | Refrigerators
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
How do we clear out the timer settings
Timer is not identified.
Open following link to identify timer and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
1) If you have zilla digital power strip, there is no reset button.
It appears you can reset timer by removing small battery located on back of timer.
Battery serves as a back-up for timer settings, and display will not show without battery.
Most battery-operated timers that do not have reset button are reset by removing battery.
Some battery operated timers retain programming forever even if battery is removed for months, and then programming is still there when new battery is installed. However this type of timer has a reset button, but zilla does not.
2) A second way to clear programming is to press PRG button to review each program, and set each program to another time. I don't know if this will work since you can't 'zero' out the settings.
Jul 30, 2011 | Coralife Power Center DayNight Timer or...
How to change the timer on a kenmore 40042
By removing back plate of washer you should see the wiring to the timer and also the timer it self. By removing the button on the front of the timer you will see two screws which remove the timer.
Feb 11, 2011 | Kenmore Washing Machines
I have a new timer to replace a broken one and I can't get the of
THE TIMER KNOB CAP REMOVES AND THIRS A CLIP UNDER IT REMOVE CLIP KNOB WILL PULL OFF YOUR SEE A SCREW OR 2 REMOVE TIMER MAKE SURE THE WASHER IS UNPLUG FIRST REMOVE BACK PANEL
Apr 03, 2010 | Maytag LAT3600A Top Load Washer
Can not shut entire timer off.
To disconnect a box timer so it does not run or control the circuit, then remove wires from terminals.
If you simply want to override timer now and then, then remove trippers from timer dial. Then use manual override switch to set timer ON or OFF.
If you remove wires from terminals, and want circuit to operate, then as a general rule, you connect black wires together and connect white wire together. However you did not specify which timer you have and timers and circuits vary, so it would be wise to test the wires.
May 10, 2009 | Paragon 4001-00 24-hr Timer Control 120v...
Machine will not advance to next function in cycle on its own.
A timer is easy to replace. Depending on your machine though if the timer is expensive just get a new machine or see if you can get a refurbished timer for less. If you remove the back panel which involves removing about 8 screws you will see the timer. Unplug the machine and just remove the wires connecting to it. Remove the few screws that hold the timer in and remove the timer then replace with the new one. Sometimes it takes a little love to get the thing out and make sure you remove the knob first from the front of the panel so it comes out. Let me know if you have any other questions.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
XL 44 Gas Range Oven temperature problem
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool dishwasher - how do i remove timer ??
When I looked up a Whirlpool 2000 dishwasher, it shows an electronic timer. For a mechanical timer, see last paragraph.
First, turn off the breaker for the dishwasher. Then you'll need to remove the Phillips screws around the inside of the door. The inner door panel lifts up, leaving the electronics in place. Disconnect the vent motor and the dispenser motor wires. Place something heavy on the outer panel to keep it down and prop up the inner panel. Remove the plastic cover over the timer - it should pop off. Remove the wires to the circuit board. The electronics are held on with one or two screws.
Mechanical timer: Turn the timer **** backwards. It should come off along with the pointer. This should reveal a 1/4 in ***** holding the timer in place.
Mar 11, 2008 | Dishwashers
Kenmore Series 70 Washer Motor 387780 Logo
129 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
