Question about Staples Office Equipment & Supplies
I have a Staples SPL77M shredder. It stopped automatically feeding paper when placed in the feed slot and now requires the forward button be pressed and held down to shred paper. If the on/off switch is left on between uses, it will occasionally start and run the motor.
    Sergeant:
  • 271 Answers
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Posted on Dec 02, 2014
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel » Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
How do I fix my auto feed, which has stopped working?
Use a flashlight to examine the shredder from the top and look for a shred of paper blocking the slot. The shred may also be blocking the sensor. If you don't find anything, turn the shredder upside down to examine the shredding mechanism from the bottom.
Mar 05, 2015 | Staples SPL770M Shredder
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
Any suggestions about Jambuster problems in a Fellowes DM-1200ct?
I think you think you are writing to Fellowes, but you aren't. You are posting to a self help website only. Your letter is good, so send it to them. The contact details are in the link. This is the sort of service we provide at Fixya.
My other suggestion was that 'are you using cutter oil', but you are.
Contact Us Fellowes
Feb 27, 2017 | Fellowes Office Equipment & Supplies
We have a Staples OB 22 Sheet Crosscut Shredder and now a light keeps coming on saying there is a paper jam. When it's turned on, the paper won't automatically go through. I have to hold a feed button...
I have the same problem but I have a staple microshredder. I thought maybe cleaning it but, that did not work. So I too am looking for a soulution. Sorry I can't help you.
Feb 09, 2011 | Office Equipment & Supplies
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
181 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
