Question about PNY Electronics - Others
My PNY Optima SD 2GB memory card locked itself! How do I unlock it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • PNY Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 02, 2014
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Have brand new PNY OPTIMA SD HC 8gb Have a HP camera Photosmart R927 Camera reads card is locked. How do I unlock the card?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 06, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
My pny 2gb micro sd memory card is write-protected, i couldn't store or delete any files. what should i do? pls help me.
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
Jul 05, 2010 | PNY 2GB microSD Memory Card
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
How to unlock Optima Digital Camera Memory Card?
You unlock the card by sliding the lock button, across, on the card itself.
Feb 20, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Electronics - Others Logo
113 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
