Question about Sewing Machines
How do i get the material to feed through
THE MATERIAL NEEDS TO BE PULLED THROUGH INSTEAD OF THE GRIPPER TEETH FEEDING IT.
  • Sewing Machines Master
  • 1,860 Answers
Depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Posted on Dec 03, 2014
SOURCE: Feed dogs not feeding material
Make sure that you did not disengage the feed dogs by accident. You should have some type of button that allows you to control the feed dogs.
Posted on Dec 27, 2008
louislevel_2
  • 374 Answers
SOURCE: Material is not feeding at all
hi there,
well, try to rotate handwheel if the feed dog move up side down,his the one pushing the fabric
this was mechanically connected to shuttle asembly.if not moving feed dog was disconnected mechanically.you mention that you use this after it was service,try to contact the serman or bring this machine where it repair.because it may have warraty after servecing.claim this it may solved the problem.have a nice day
don't forget to rate me'
thank's.
Posted on Apr 10, 2009
louislevel_2
  • 374 Answers
SOURCE: material won't feed
hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Posted on Apr 19, 2009
  • 96 Answers
SOURCE: Sears Kenmore Sewing machine model wont feed
you need repair service for that one
Posted on Dec 13, 2009
  • 539 Answers
SOURCE: Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Posted on Apr 07, 2012
My machine is not feeding the material through by my feed dog and t it want let it sew properly
Is it an older mechanical? If so, probably needs a good cleaning and oiling. The old oil has turned to goo and is sticking moving parts together.
Dec 11, 2015 | Riccar Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Mar 27, 2015 | Sewing Machines
The feeding teeth on my kenmore model number 15813513 have dropped and i dont know how to get them back up to feed the material through
since it's a kenmore sewing machine call sewvacdoctor.com
and ask them how to get the feed dog back up
(800) 544-5858.
Oct 22, 2012 | Kenmore Sewing Machines
Apr 04, 2012 | Singer 4423 Sewing Machine
The material wont go through you have to pull it rather than the machine feeding it the sewing machine is a singer inspiration 4205
Maybe you should check your feed dog it may be down instead of up to walk the material thru...
Jan 17, 2011 | Sewing Machines
The material will not advance in my Husqvarna Viking 775.
The first thing to observe is if the feed teeth are coming up above the needle plate. Remove the presser foot and unthread the needle, then rotate the handwheel (always towards you, never away from you) and check to see if the teeth come above the plate. The button next to the on and off switch drops the feed teeth, so make sure it is in the up position. Pushing on it when its down makes it pop up and then after the machine makes one revolution the feed teeth pop up for normal sewing. Also look on the left side of the machine and you'll notice a dial, that dial should be on 6 for normal sewing. If everything I've covered so far is correct, the dial is on 6, the teeth do come up above the needle plate and your plate is correctly on the machine and you still don't have feeding it's more than likely a computer problem and a service to your tech is in order.
Oct 04, 2009 | Husqvarna Viking 1
Not feeding
Hi, most likely you don't have enough presser foot pressure. Adjust accordingly. Are the feedogs up and not in darning mode?
Rick
Mar 26, 2009 | Bernina Virtuosa 160
Feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Nov 24, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
85 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
