Question about Samsung Computers & Internet
Having had no problems with my Samsung wireless LAN adapter for 12 months, I now receive a message saying "No Samsung Wireless LAN adapter connected".
I have 32" Samsung UE32F5300AKXXU TV with a WIS12ABGN/XEC Allshare (DLNA) Smart TV Wireless Dongle
sandrew
  • 2961 Answers
SOURCE: wireless 3crusb10075 problem
Sounds as if your router may need to be set to enable wireless connection and enable DHCP, this alocates your wireless adapter an I.P Address automatically. If this is alraedy the case, check the properties of your adapter to see if it's set to recieve I.P address automatically. If still no joy find your routers I.P. address and DNS address (this is what you type in your web browser to set it up). If your router is 192.168.2.1 or similair, set your adapter at 192.168.2.2 and the same DNS address normally 255.255.255.0. Restart both pc and router and try again. Also make sure network sharing has been set up via the XP wizard.
Posted on Dec 14, 2006
SOURCE: No connectivity for wireless usb adapter
could mean that you dont have the proper driver for your current Dell 1450 (D1450U) Wireless Adapter What operating system are you running I would be happy to find the driver for you.
Posted on Jan 03, 2010
gymowner
  • 679 Answers
SOURCE: when connecting the samsung lan adapter to my sams...
There should be a reset either hard,"button" or soft, Plug in the computer and run any software that came with it, Please let me know how you made out, I have been wanting to run my pc movies into my Sammi at the other side of the house, but most of the products I looked at have spotty service at best, There is a new one at Best Buy , that does live streaming in hdmi if you already have the adapter, for lie 60-70 dollars, I will await your response,
Gymowner
Posted on May 22, 2010
  • 88 Answers
SOURCE: Hi guys, I have an
Right now the security on your LED is set to 64 bit wep - now you need to change security on LED to wpa/wpa2 and that will solve your problem .
Advisable :if you can make sure what kind of security is been enabled on your wireless router (wep 128 bit or wpa/wpa2 ) that will be more helpful for you to select the security on led - give a try with wpa/wpa2 .
Posted on Oct 04, 2010
  • 107 Answers
SOURCE: Cannot stay connected on wireless
Hi, Please make sure that you have turned on the wireless switch on your laptop because this is a message that usually appears if the wireless on the laptop is disabled.Also please update the wireless drivers for your laptop from the Toshiba website. Thank you for your time and best wishes for your effort.
Posted on Jan 08, 2011
Why would my samsung smart tv won't connect to my belkin a46 router.
Although there is a menu for wireless connection, unless you purchased a separate SAMSUNG wireless LAN adapter, you cannot use the wireless connectivity functions of the TV. You can use the regular wired LAN connections however. (see users manual for more details
http://downloadcenter.samsung.com/content/UM/201103/20110324091218633/%5BENG_US%5DGSATSCA-1017.pdf
Mar 01, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Do not see the usb pop up
Make sure you have installed all of the correct drivers before inserting the wireless device. The drivers are located on the CD you received with the product or can be downloaded online @http://www.samsung.com/us/support/downloads
May 03, 2011 | Samsung WIRELESS LAN ADAPTER...
When connecting the samsung lan adapter to my samsung led tv 8000 series a message appears saying that the device is connected and set to cable asking if one wants to change it to wireless or not. But if...
Gymowner
May 20, 2010 | Samsung WIS09ABGN (8808993304486)...
I'm having a problem setting up my linksys wireless router. My computer sees the connection but will not connect to it? I've tried the repair option and tried to add a network with out any luck.
As i remember Linksys goes with Straight Through Ethernet cable. Always, good thing is to connect your computer to Wireless Router using LAN port. Set DHCP (Automatic) connection for your computer. After receiving ip from router you can setup your Wireless Router using GUI, and setup your Wireless Network, SSID/Security. From adapter to adapter there can be some misc problem with WEP/WPA/WPA2 and so on, so it maybe your issue, or OS blocking connection to Wireless Networks without security.
Apr 18, 2010 | Linksys Wireless-G Broadband Router
Connection problems with ASUS WL-167 G
Try going to "network and sharing centre" click "internet options" then click "connections tab" then "lan settings" check if it is set to "automatically detect settings". If this is clicked then maybe look through the guide or contact microsoft (if using windows that is!!)
Feb 02, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
D-Link Wireless Router WBR-1310 wont connect?
- Check LAN cable
- Use a different cable
- Use "crossed" LAN cable
Oct 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
XBox 360 Adapter hardware conflict
Check the XBox LAN configuration maybe it is enable?, if you have the option to disable the adapter then disable it. Then try installing the wireless adapter again.
Note: If you have a hardware conflict, its a compatibility issue. Then the next option that you'll needing to do is to find an another adapter that is compatible to the XBox.
Mar 07, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Computers & Internet Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
