We have an Atria 3000 machine that keeps displaying the message "Front End Failure". What does that mean?
2 Suggested Answers
  • 45 Answers
SOURCE: We have an Atria 3000 EKG machine. It is displaying the message "Front End Failure" Help!
It's a guess but I think the "keyboard" and its associated processing parts are fried from a staticelectricity charge hitting the unit. See page 4-8 of the linked manual which references a "Front End Digital Board".
Good luck if you try to repair as Motara issued an End-of-Life notice effective 8/1/13 so no official repairs or parts are available (second link).
http://photos.medwrench.com/equipmentManuals/5658-3399.pdf
http://www.mortara.com/index.php?eID=tx_nawsecuredl&u=0&file=fileadmin/user_upload/support/International_Distributors/Marketing_Support/Product_Notifications/EOL_Atria_3000.pdf&t=1417648515&hash=d8f9cc5b3b87eb25ec9120c5c6f38825
Posted on Dec 02, 2014
Dec 02, 2014 | Medical
I am getting an f71 reading on my whirlpool front load washer wfw9500tc01
USER INTERFACE HEARTBEAT FAILURE
If a central control unit heartbeat failure is displayed, no communication is detected from the user interface (That's the buttons and dials on the front to you and me!).
The online manual (which is unnecessarly wordy AND has a block on it so I cant copy bits and paste them here and have to retype them all again) says:
Check for continuity of the harness for the user interface (That means take the top and the front off and make sure no wires have dropped off or are broken on the connections to the front panel)
Check wire harness connections to the user interface and the central control unit (That means check the plug hasn't come off the front panel or at the other end of the wires to the main controller burried down at the bottom of the machine)
Replace user interface if drum is rotating (Get a new front panel if the drum still goes round when you switch the thing on)
Replace central control unit if drup is nott rotating (replace the main controller burried down at the bottom of the machine if you try to get the machine to run and nothing happens at all).
Hope this helps
Jul 06, 2011 | Washing Machines
How to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Oct 17, 2009 | Brother MFC-9840CDW Laser Printer
Getting error message #5UD and F35
F35 ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
IF YOU GET ERROR MESSAGE SUD
SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
Please rate this solution
RNJ VINODKUMAR
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Feb 06, 2009 | Brother IntelliFax-2820 Laser Fax
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Error message 07,010.43:41188
That error message means that the print head is not moving properly from the home park position to the print position.
Here are the mose likely possibilities.
1 Ink has spilled out and into the stainless steel block that the print head pivot shaft goes through. With the covers off looking from the front it is on lower left about mid machine, about 1 inch square. Would most likely have yellow ink in it.
2. You had a power failure or unpluged the machine without powering it down properly and the Print head wiper is tacked to the print head not allowing it to move.
3. One of the cables that are connected to the print head are keeping it from moving properly.
4 The Media motor gears are out of timing. That is not very likely though.
Also, to prevent this, you need to be sure the machine is level front to back and side to side.
I have seen one print head defective leaking ink into the bottom of the machine making a huge mess.
But that code is definatly related to the print head not being able to pivot freely.
Jan 17, 2008 | Xerox Phaser 8500/DN Printer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
