Question about Kenmore Washing Machines
Timer will not advance - Kenmore Washing Machines
If the washer is 20 years old or more
& the timer is the problem--replace it
(If it has a separate electric timer)
Have to remove the from control panel- to see that
You go to an appliance parts store,
the pros go to- for the part
About $80.00
Posted on Dec 02, 2014
Defrost timer does not advance after defrost
During this time of defrost you manually advanced into, Did the heater turn off them self? If they did the defrost thermostat does work, if the heaters stayed on the entire time (1hr) than the thermostat needs to be replaced as well as the timer. The thermostat is a cut off device to prevent the over heating of the freezer and liner (safety device). Think of a defrost timer as an egg timer, this timer runs regardless of function just advances like a clock. The thermostat turns off the heaters when they reach a temp rather then time. I hope this answered your question, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2014 | Refrigerators
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
Dryer timer doesnt advance.
If the timer does not advance even on the time dry cycle then you have a bad timer motor. You would need to replace the timer to rectify the problem. Hope this helps _MJ_
Apr 27, 2010 | Roper RES7646KQ Electric Dryer
Timer will not advance into defrost. Replaced timer 3 times.
If you have recently replaced the timer with a new one it's likely you need to make a wiring modification to the timer for your machine.
Aug 23, 2009 | KitchenAid Refrigerators
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
