Question about Optoma RD65 65" Rear Projection HDTV
No picture i have the RD65 and lost picture and had a solid red light in front for the lamp indicating a problem with the bulb. when trying to turn the tv on it makes a whining noise not continuous but intermitinly. after a red light for the power and lamp both come on and the tv shuts downs.
Re: no picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Posted on Feb 07, 2008
0 characters
3 Points
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Feb 01, 2013 | Mitsubishi Projection Televisions
I need to change the bulb in my WD65731 dlp tv. I have taken the cartridge out. How do I get to the bulb. I repleced my lamp and still have no picture. Am still getting a "blinking" lamp light on front...
The blinking lamp light refers to the lamp door not being closed. There is a little lever behind the main panel and if that's not shut, the lever won't be pressed in and therefore the light blinks. If it's a failed lamp, the lamp indicator light will be a solid, not blinking.
May 31, 2009 | Mitsubishi WD-65731 65" HDTV
Replaced bulb stil issues
In most projection televisions if a solid light comes on there isn't anything wrong the bulb there is a problem with one of several cards in the back of the television. I'd check for over heating damage on your imput cards, the Controller card that is connected to said input card, or the relay card that controls the tube output. Keep in mind you did order a part off of Ebay which is untrustworthy in and unto its self.
Sep 01, 2008 | Optoma RD65 65" Rear Projection HDTV
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Jun 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
After lamp replacement
Sounds like the plug is not making a good connection needs to be seated better.
Dec 10, 2007 | Optoma RD65 65" Rear Projection HDTV
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Optoma RD65 65" Rear Projection HDTV Logo
148 people viewed this question
Top Optoma Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Optoma Projection Television Expert? Answer questions, earn points and help others
