Question about Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB RAM 320GB 5400 RPM HDD SuperDrive Mac Notebook
How could I change the main screen by default when I use another screen with the laptop
    Sergeant:
  • Apple Expert
  • 209 Answers
I am guessing that you are referring to your "Home Page"
If so, click on Safari, then Preferences, then General.
You can then type in a specific address or click to set it to the page you are on at the time. It will then make that your home page which will open each time you open Safari. I hope that was what you were asking.
How could I change the main screen by default when - 25304476-m2kkf5dz3lzfn1ctxe501m0b-2-0.png
Posted on Dec 03, 2014
Testimonial: "Thank Cedric. It's not exactly my question. I work with a laptop and I plug another screen to work with 2 screens. (the screen of the laptop and the another bigger screen) I want to have all the windows and information on the bigger screen instead of on the laptop screen. For this moment, the alert window or save window appear on the laptop screen when I work. But I want to use the bigger screen like the main screen. Thanks !"
  • Cedric Zumwalt
    Cedric Zumwalt Dec 03, 2014
    Ok I see. Try looking at http://techchannel.radioshack.com/hook-u...
  • celine Dec 03, 2014
    thank you cedric it's exactly what i have searched! very helpful and clear
Asus laptop blank screen after seting to default in boot menu
You might have change the boot screen in the BIOS. You need to connect it to a screen or TV that has VGA port. Try from there if you get in Video or HDMI. By default F10 is for BIOS menu some may vary.
Jan 26, 2014 | Computers & Internet
Dell laptop not working
Usually the problem is with memory or hard drive or an old driver, mainly video. Try downloading GWSCAN 5.12 and run a quick scan on your hard drive. You can also download Microsoft's memory test and burn that on a CD, boot off of it and see if there are any memory errors. If your video driver is old, it can cause this as well. Try and update that if you can. Of course, malware or viruses can cause this as well.
Jun 25, 2013 | Computers & Internet
My asus laptop screen is divided into diffrent desktop
Right click on the main screen, go to properties, go to display options, change the display settings so number 1 box is bigger and to the left of number 2 box, all other settings should be set to default.
Jun 09, 2012 | ASUS Computers & Internet
What is the the default CMOS/BIOS settings for HP 520 Laptop
Go into bios and select factory default, it will ask if you want to save the settings enter yes, when you exit the screen press F10 to exit and save all changes, on your laptop the key choice may be different so look at the bottom and double check. This should fix your problem, you may need to reload windows again.
Mar 21, 2012 | HP 530 Laptop KP471AT
How to restore default setting to display i am using Hp w17e
On your main screen do a right mouse click and in the drop down menu, select properties or screen resolution. That should bring up your screen settings, normally they show which setting is the recommended setting.
Dec 31, 2011 | HP w17e Monitor
I had lost my Dell Latitude D600 Bios passowrd. So I removed the comos battery (behind main battery) and reinstalled it. But now my laptop is giving this message on bootup "invalid system...
  1. Set the BIOS to defaults:
  2. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
  3. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  4. Use the "Alt" + "F" key combination to load defaults.
  5. Press "Esc" on your Dell laptop keyboard to save and exit.
  6. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 22, 2011 | Computers & Internet
When I use the external monitor S-video port on my Dell Inspiron 1721 running Windows 7 it only displays in black and white despite the internal monitor showing the screen in color.
Okay. For Windows Vista OS.
Go to Control Panel.
Under the Control Panel Home, select Additional Options at the bottom right of the list.
Click on Appearance and Personalization:
At the top right corner of the dialogue box, under Personalization, select "adjust screen resolution"
This will bring you to display settings:
Click the button that says "identify monitors" As each is displayed, it will present a number for which is the default or main monitor (1 or 2) 1 is the main monitor.
To change the external to the main or number one monitor: simply drag the #1 monitor to the left side (if not already there) If it is, you'll want to set the external as the default:
Do this:
While in Display settings, if the external is the #1 monitor, make sure to check the box for "extend the desktop to this monitor" and "this is my main monitor" for the external display. This should switch all settings to the external monitor.
Also, make sure the the resolution is correct for the size monitor you have. For a 20" (such as mine, external Dell monitor) the resolution is at the highest (1920 x 1080).
Also make sure it reads (to the right of that) "highest 32 bit). If this is not an options, make sure you're adjusting the external monitor and not the laptop screen. Otherwise you may need to upgrade your video card.
You should not need to do this though.
After you have set this, go to Advanced Settings and select Monitor. You will see at the top, a list of two monitors; your external with it's brand and name - and the laptop screen type and name. Select the external monitor name: Click on properties, drivers and Update Driver, then select to Automatically search online for driver.
Please let me know if you need further assitance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
My MacBook will not boot up
go to bios setup load optimal defaults.
then save.
Nov 12, 2008 | Apple MacBook Pro Laptop Computer with...
Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
ps: defected processor could be the cause
Nov 14, 2007 | Dell Latitude C640 Notebook
Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB RAM 320GB 5400 RPM HDD SuperDrive  Mac Notebook Logo
69 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
