Question about Sole Fitness F63 Treadmill
My Sole F63 was working fine. One day, after we unplugged the treadmill and plugged it back in, the treadmill went through a start up process. It elevated the desk for a couple of seconds and stopped and gave an ELEVATION ERROR message. I tried it a couple more times, and the deck would elevate and not go back down. I tried recalibrating the treadmill. I followed the instructions and when it started, it would raise the deck to maximum height and then only go half way down. I tried pushing start and down while inserting the key, but that did not do anything. I tried going into the maintenance mode and the only thing I can get to there is KEY TONE. I just tried reconnecting the wires from the incline motor that plug into the main control board. The main gear shaft looks well lubed (we hardly use the incline feature). I ran the recalibration again and this time I noticed the LED light for UP INLCINE goes on when the deck moves up. The DOWN INCLINE LED goes on, but nothing happens. I am assuming it is the motor, but I would like to hear your opinions before I purchase one.
  • 4 Answers
My treadmill had stopped with the deck raised too. I had to pull the wires to the motor to drive the deck back down, then turned the unit off. My motor has three wires going to it, Up, Common, and Down. To lower my deck I disconnected the Up and Down wires. Then I connected the Down wire to the Up plug on the control board. Thereby when the control board told the motor to go up it went down.
After lowering the deck my fix was to lubricate the treadmill deck using a kit from a famous Sporting Goods store. Then the unit passed calibration and its been running well since. I had never lubricated the deck and track. I couldn't tell by rotating the treadmill tread that it needed lubrication. Nor could I tell a difference after lubricating the tread.
Why the machine raised the deck and wouldn't lower it because the tread needed to be lubricated is a mystery. I think in my case I obtained a speed error, probably due to a little too much drag from the tread. Then failing calibration for speed must have corrupted the up/down calibration. Then turning on the unit caused it to raise the deck and not allow me to lower it.
Please be careful if you are rewiring your motor to lower the deck. Unplug the unit first. Make your changes, then plug it back in. Then unplug the unit to return the wiring to its original position. When the Up wire is disconnected make certain that it does not short out or touch anything. It might be safer to connect the Up wire to the Down command, ie switch Up and Down as suggested by Art. (On my machine Up is Red, Common is White, and Down is Black, so Art's suggestion of switching Red and Black would be correct.)
If rewiring your up signal to drive the motor down works, then your motor is okay and there most likely is an issue with the down circuit. Or you are lucky and just have to lubricate your deck/tread, then recalibrate as I did. Good Luck.
Posted on Dec 05, 2014
  • 20 Answers
I would check the main wiring harness, from the motor board to the console. Check the connection where the main frame connects inside the right upright bar. Remove the triangle shaped plastic cover bolt and side it up the upright bar. You will see the harness. Pull it through the acess hole the check the connection.Make sure all connections are tight.inclines motors rarely fail. To get it down you can reverse the red and black wires from the incline motor to the motor controller. Then run the calibration, once it's down just pull the safety key. It could be the display board or MCB
Posted on Dec 03, 2014
Just bought sole f63 runs data press start nothinges e4 is displayed then not happy
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 07, 2016 | Sole Fitness F63 Treadmill
My sole F63 treadmill is stuck up in the storage state. I tried to use the yellow lever and it isn't lowering and I can not use it!
Lift the treadmill slightly to take pressure off of the locking pin as you work the release lever.
Oct 08, 2014 | Sole Fitness F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Sole F63 treadmill controls won't work
Stuck button or bad hand switch. Remove covers between hand rails and console disconnect both hand switches should fix it.
Jul 06, 2014 | Sole Fitness F63 Treadmill
Treadmill Elevaton Error
There are a few things you may need to check. You already tried calibration. Next thing I would do is check the sensor wire from the incline to the controller. Make sure its properly plugged into the controller. The controller can also be an issue. If someone was tampering with the unit, the sensor wire could be plugged into the wrong connector as there is another connector that will fit. You may contact me for phone support or sign up for phone support at Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Mar 24, 2014 | Sole Fitness F63 Treadmill
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Sole f63 key
please download the owner manual from www.fitness.manualsonline.com and see the section how to assembly and reverse and proceed according.
God bless you
Dec 17, 2012 | Sole Fitness F63 Treadmill
Sole Fitness F63 Treadmill Logo
368 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
