Question about Poulan 530071835 Primer Bulb Pump For Chain Saw Sears Craftsman Weedeater
Hook my 2 hoses from gas tank to carborater
Put 2 new hoses in and it will only run at full shoke
  • Eugene Rounds Dec 02, 2014
    Hi Greg Minkel, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Did the lines back the way they were originally or was they already disconnected? Also did you clean carburetor internal filter screen? The model of equipment woould me to look-up how the lines should be connected.
  • 743 Answers
Watch for collapse lines especially on the fuel filter side...if it is yellow, they are a problem. Make sure that you don't have the primer side on wrong, but if so; it will collapse the primer plunger.
Posted on Dec 03, 2014
    New Friend:
  • 61 Answers
You need to make sure the I.D of the hose are the same. to small not enough fuel, to big and it could get flooded. also remove fuel bowl off carb and make sure there's no trash in carb if so get a rebuild kit. take carb with you that way your parts man has model# and whatever he or she needs
I just replaced the gas tank in my 1990 dodge pickup 150 now i cant get it to stay running i need help trouble shooting i may have hooked the hoses back up wrong idk i need a fuel systems diagram
They should be 2 different size hoses so can't get them wrong. if you replaced the fuel pump/guage in tank may be bad. can try to cycle the key a few times.
May 24, 2017 | Dodge Cars & Trucks
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Gas tank will not take gas
Something in filler tube or something making gas pump think tank is full. I had same problem someone had put paint balls in my filler neck
Aug 06, 2016 | 2006 Suzuki Forenza
RYOBI 310BVR blower gas line from tank to primer to carb to tank diagram
the primer bulb has 2 out lets on it the short one feeds the car and the long out let feeds the tank Slice the hose to the tank and feed it intothe tank about 8 inches and hook out with a wire hook to cut the slice off and put on a new filter. Push it into the tank and be sure lays on the bottom of the tank..
Jan 27, 2016 | Ryobi Garden
Engine starts for two minutes then shuts down
THE HOSE MAY BE A GAS FLOW HOSE OR BLEEDER. IT COULD BE YOUR SPARK PLUGS IS DIRTY AN IN THAT CASE IT WILL NOT ALLOWE IT TO BURN GAS IT WILL CAUSE IT TO CHOKE .ARE IF THAT DONT WORK DRAIN ALL THE GAS AND MAKE SURE THAT YOU HAVE A OLD RAG AND A SCREW DRIVER ARE SOME SORT STICK THE RAG IN THE TANK AFTER DRAINING THE GAS AND CLEAN THAT TANK REAL GOOD AND REMEMBER DRAIN YOUR CUP THATS HOOKED AND THE CARBORATER THAT SHOULD BE ONE SCREW THAT HOLD THE CUP IN PLACE THEN YOU HAVE A LITTLE SMALL CUP THAT IS REALLY CALLED A FILTER MAKE SURE THAT THE OLD GAS IS OUT ALSO. PUT FRESH GAS IN IT AND IT SHOULD FIRE RIGHT UP
Dec 18, 2012 | Honda Black Max 3000 Psi Pressure Washer
How to repair leaking fuel lines under the tank
Okay, prepare to get some gas on you. You need to drain the gas
You'll need:
1 pair hemostats or hose pincher
1 pair of wire cutters
1 screwdriver phillips or flat head
1 nut driver 1/4 inch or 5/16 inch
New fuel line. (cut 1 two inch piece and put the bolt in one end making a plug) = 2 inch plug
Hose clamps.
1 Bolt that will fit inside fuel line.(make line plug)
Pinch either side of the fuel line with hemostats. Cut the factory clamp off and pull the hose off. Put the 2 inch plug on the tank,and that will stop the gas from coming out. put a hose clamp on it if you want so it don't leak.
Now put a gas can under the pinched line and unpinch it and let the gas drain out of that tank.
When done draining , cut that hose off the tank and put it on the other side where that plug is. Remove the plug and put that line on and let that tank drain.
Once the tanks are drained., Just cut the hose to length and replace, using new hose clamps and new fuel line.
If your quick enough you can swap the hoses out without draining the tank.
You will get gas on you no matter what.
Dec 02, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I need to get the bad (old) gasoline out of the tank, but can't insert a hose into the tank to siphon it. How do I get the bad gas out?
How much bad gas?
If you have a half a tank or less put cup of paint thinner in the tank,fill it up w/good gas, you should be fine.
Make sure the thinner is in the tank first,or it will just lay on the top of your gas.
Now if you have a full tank of bad gas, do this:
On the passerger side underneath I believe there is a gas filterjust behind passenger front seat, Remove filter you need a new one,put a hose on the line, turn on ignition and pump it into a very large container,
replace filter, put new gas in
Jul 24, 2010 | 1998 Jeep Grand Cherokee
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
Aug 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan 530071835 Primer Bulb Pump For Chain Saw Sears Craftsman Weedeater Logo
114 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
