Question about Tascam DP01 All-In-One Recording Package Microphone
TASCAM DP-01 won`t startup
I bought a Tascam DP-01 through a marketplace. But he does not. At startup, it stays on please wait. I have deployed a new hard disk, but the problem remains the same. I need the new harddisk first provided with a partition? Because the unit 2nd hand is there is no guarantee anymore. Who can help me?
    New Friend:
    Problem Solver:
  • 4 Answers
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
Posted on Dec 28, 2014
4 Suggested Answers
SOURCE: I need a driver for a Tascam DP-01FX
ok first i just wanna prepare ya on how bad your gonna kick yourself on this one, i have a used one and dont really use honestly i hate it...but i decided to mess around with it and decide to get sumthing decent and bring it to the comp for the first time...and i seen i had the same issue.. and saw that alot of people did to and they went on and on with no solution...so i gave myself 5mins to think and remember....and here ya go you ready... after you save all your songs correctly to get them ready for export...step 1.plug it into your usb port...step 2. ignore the fact that its not being noticed by windows...step 3. go to menu on ur tascam scroll down to disk hit yes/enter.step 4..now ur in the disk menu and right there the third choice..usb open/close hit enter and there ya go you will be prompt to open the usb port and everything is done your ready to go...when ur done u close the port...basicly an on and off switch for the usb port...i hope it helps and its not too late...good luck..oh it should be in the manual under usb...thats how i remembered it cause i remember reading it.
Posted on Jul 21, 2009
  • 189 Answers
SOURCE: Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Posted on Jan 05, 2008
  • 189 Answers
SOURCE: what kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Posted on Jul 24, 2008
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
TASCAM DP-02 (You don't even include it here in your products!)
Here's a link to the DVD tutorial for the DP-02:
http://www.amazon.com/Tascam-DP-02-Video-Tutorial-Manual/dp/B001JP6572
There is also a video on Tascam's support page for this product that you can download for free:
http://www.tascam.com/products/dp-02;9,16,3580,19.html
You can ask questions here or consider joining Tascam Forums (I think it costs $4) and talk to Tascam experts from all over.
http://www.tascamforums.com/
The DP-02 operates almost exactly as the DP-01 did, so manuals and videos for one should pretty much guide you correctly when applied to the other, but the video in the first link is the correct on for the DP-02.
Hope this helps.
Best of luck.
bd.
May 08, 2009 | Tascam DP01 All-In-One Recording Package...
My computer won't recognize my DP-01 Tascam recorder.
open the usb port on your dp-01 by going to "disk" in the "menu" select "usb opn/clse" press enter twice.
if your pc is connected to ur dp-01 it should reconize it, open the files by going into my computer as you would with a memory stick or card.
Mar 25, 2009 | Tascam DP01 All-In-One Recording Package...
Can't Get My Music Off My Tascam. I have a DP-01 portastudio and it has a usb connection but it's not being recognized by my computer. At first it just wasn't compatible with Vista now I have windows xp...
How to export your recorded tracks to WAV:
- Activate the Menu
- Scroll down to WAVE
- Press the right cursor key
- Go to Export Track
- Select the tracks using the Insert and cursor up and/or down keys
- Press Yes/Enter
- When the DP-01 is done repeat pressing Exit until the menu is closed.
Tascam USB mode:
- Press Menu
- Go to Disk
- Scroll down to USB OPN/CLS
- Press Yes/Enter
- Press Enter again to execute
- Press Yes/Enter again for the "Are you sure?" message
Now you will be in USB mode and you will be able to access the DP-01's hard drive and download the exported WAVE file(s).
Remember: the DP-01 will stay in USB mode until you remove the deviceusing the Safely Remove Hardware option in Vista and then press Exit onthe Tascam!
Oct 18, 2008 | Tascam DP01 All-In-One Recording Package...
What kind of driver does my tascam dp 01 cd take.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Need a manual
Here is the location for the manual:
http://www.tascam.com/products/dp-01;9,16,33,19.html
That site has the quick install guide as well as the manuals for the different dp-01 models.
Jun 19, 2008 | Tascam DP01 All-In-One Recording Package...
Jan 05, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
314 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
