Question about Directv Televison & Video
How do I program my directv remote to control power Acoustik sound bar?
I would like to control sound +/- with directv remote. At this time I have to control the volume with the soundbar remote.
  • Directv Master
  • 3,287 Answers
Bill,
Directv remotes come with specific manufacturers and models built in. Newer model remotes have more products programmed in. If a product came out after the Directv remote you have was made, it may not work with your device.
Contact Directv to determine IF they have a remote that WILL work with ALL of your devices, or not. If they do not, you will need to either use multiple remotes or purchase a universal / learning remote that WILL.
Posted on Dec 02, 2014
cammykins
  • 149 Answers
SOURCE: Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Posted on Sep 24, 2007
SOURCE: phillips directv remote RC19041003
I had hte same problem but I found the web site her is the web site for phillips directv remote rc19041003 it is in pdf it is the user manual
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX5500_5540.pdf
Posted on Dec 03, 2008
SOURCE: Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Posted on Jan 23, 2009
SOURCE: Codes for directv hr21-200 and logitech z5500
This forum says its 1408 or 1429 selecting Aux however that did not work on my scientific atlanta Cox remote.
Did you get any better solution
http://forums.logitech.com/t5/Speaker-General-Discussion/I-can-use-a-universal-remote-controls-for-the-Z-5500/m-p/94004
Posted on Jan 19, 2010
danbusa
  • 185 Answers
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
Posted on Dec 29, 2010
Need the codes to program the remote to operate the sound bar
[PDF]Remote User Guide - MyDISH
https://www.mydish.com/filestream.ashx?ID=3037
remote. The standard setting for TV2 operation is UHF. If you wish to use. IR signals ... The on-screen bar ..... a remote-controllable audio receiver or amplifier.
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVLearn how to program your DIRECTV remote control in just a few short steps and ...control up to four devices, such as your TV, HD DVR, DVD player, and audio ...
Is it possible to have DirecTV remote control sound bar volu
Dec 21, 2015 | Televison & Video
Program directv remote to Maxell soundbar
Hi, you will need to access the operating manual for your directv remote. It will have codes in the remote. but most likely it will not work your soundbar as most Directv remotes do not have codes for them, and do not support them. You are stuck using the soundbar remote for your soundbar. The only option you can do is to purchase a learning remote from the store that can program to your directv box and your TV, and you can learn the volume keys to your Maxell sound bar.
Oct 13, 2013 | Maxell 193002 ssb1 soundbar
Need a code for toshiba sbx3250 for directv universal remote
Check these codes: 10154, 11256, 10156, 10060, 11704, 10845,
11656, 10650, 11356
Dec 14, 2012 | Toshiba SBX4250 - Powered Soundbar and...
Yamaha YAS101 sound bar does not work on DirecTV remote control
Try this solution:
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/?current_page_id=1&sort=undefined&type=
Jun 22, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
The Directv codes for my Samsung HT-TZ512 surround sound/dvd player don't work. How can I program my Directv remote to control the dvd player? The codes I've tried are 20490, 20573, 20820, 21075 and 20899....
sometimes directv remotes do not work with surround dvd players. Try doing an automatic code search . Most of the time it will only allow you to power the dvd player and operate the volume.
Oct 23, 2009 | Samsung HT-TZ512T Theater System with...
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
98 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
