Question about Kitchen Appliances - Others
How do I clear a yellow light on my Scotsman ice maker?
I cleaned the machine. after that the yellow light is not removed. it only make two clycle of drops then it switches off.
  • 100 Answers
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Posted on Jan 14, 2015
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
  • 129 Answers
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Posted on Feb 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 7 Answers
SOURCE: Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
Reset clean light
Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
Apr 24, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
How to reset after cleaning
Once you run the unit through the cleaning cycles the light will clear it's self and start the controller on a new count down. If controller dose not clear the light then the controller will need to be replaced. Now with that the controller will still run the machine and work fine a control board is not cheep and as long as you clean the machine every 6 months it will be ok.
Sep 04, 2013 | Scotsman Ice Machine, Cuber, 1930 lb....
Black flakes
Dose the whole cube have a black tint to it? or dose it have black flakes in it? If all the ice has a solid black tent to it then check your water filter most all filters has charcoal in them when you change one out and apply water to them you need to dump the ice until you get clear ice. Now if it is just black flakes in ice than you need to clean the ice machine with scotsman cleaner nickle safe and scotsman sanitizer follow manufacturers instructions.
Aug 30, 2013 | Scotsman Kitchen Appliances - Others
How ofter should you clean the Scotsman ice maker?
Every 6 months and change filter unless you notice ice hanging up during harvest and dirty ice then i would every 3 monts.
May 25, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
We have four Scotsman Ice Makers. The curtains are beginning to turn a little green. What is the approximate cost of replacing these curtains. How much per curtain?
Unless they are terrible you can clean the curtains. What you do is put icemaker cleaner in the icemaker and run it through a cycle. I don't know how much the curtains cost.
Sep 28, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My Scotsman is making ice but the level at which the bin retains ice is getting to be less and less. The drain is clear and the hose is connected. thoughts? TK
Clean condensor and evaporator. Check spray nozzles clear. If you can lower the room temp and it produces better then likely a dirty machine, low on charge or weak compressor.
Aug 01, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Cme256 scotsman ice machine
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Kitchen Appliances - Others Logo
99 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
