I have model ssd200ta. Works great except once room temperature reaches it' setting, the front row burner stays on and back row turns off. The problem is the gas smell increases during this situation and we have to manually turn it off. I need help.
    Novelist:
    Scholar:
  • 165 Answers
Works great?!? This is a gas heater that reaches temperature and then you smell more and more gas? STOP USING IT! You may kill yourself from inhalation of the gas and it may explode from a spark, such as an electrical switch activating, not only killing you but blowing up the structure you are in. disconnect it and have a licensed professional troubleshoot it. This is not a do it yourself type of project. Sorry. this is a real danger. Don't end up on the evening news.
Posted on Dec 02, 2014
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
Is it normal for my furnace to have burner cycle once or twice
That sounds normal. When the bonnet reaches a preset temperature the burner turns off then when it cools down a bit the burner turns back on. Clean filters etc will help to keep the burner on longer in a cycle.
Aug 24, 2014 | Heating & Cooling
On our glass top GE Profile stove, the burners do not stay on - they keep turning off and then on again before coming to full temp. Extra long time, for example, for water to boil.
They cycle off once they have reached the temp that you set, then come back on to keep that temp, my suggestion is increase the set temp.
Dec 01, 2013 | Cooktops
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
Rinnai reh15-217 burners cut out automatically after being on for about 1/2 an hour
If you're saying the burners turn OFF after 1/2 hour, but the pilot light stays lit ... I'd have to assume that the automatic thermostat control on the heater, turned the burners OFF, because the temperature you had it set on had been reached. The real question (at least for me) is are you allowing enough time for the temperature to drop and the heater to turn back ON automatically?
May 16, 2011 | Heating & Cooling
I have set the times for the heating to come on and put it to auto but it doesnt seem to come on at the times i've set it at??
If the Procom Model number you referenced is correct, this heater does not have a automatic timing feature to turn the heater On and Off. However, it does have a built-in thermostat control, that turns the heater's burner on, once the room/area drops below the temperature/comfort level you have set it for.
Conversely, it turns the burner Off once it reaches and holds the temperature/comfort level for 5 minutes or more, it turns the burner OFF, again. Keep in mind, because this is a built-in thermostat, it's reading the air temperature closest to the heater.
If the thermostat feature is what you're having a problem with, it may be that the sensor bulb has failed (assuming it's not turning ON & OFF automatically). However, this is a fairly rare failure. Unless, the heater is very old or hasn't been cleaned and serviced annually.
Another situation would be that the Control Knob has been left in the PILOT position, rather then the ON position. If that is the case, the heater will not turn ON, period.
Right now, your Owners Manual is your best source of information on the correct operation of the heater, as well as it's Trouble Shooting Guide.
If you have misplaced the Owners Manual, here's a printable link to it. Just locate the Model Number of your heater, ML300TB and click on the icon to the left of it.
http://www.usaprocom.com/manuals.php
Hope this helps you solve your problem.
Mar 03, 2011 | Procom ML300TBA Heater
Won't shut off when reaching preset temp
Sounds like a thermostat problem or a short in the wire. Can you give us more info like is it gas or electric and model numbers will help.
Thanks.
Oct 11, 2007 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
