My LG55(55LD520) powers on, but no picture or sound. There was some sort of electrical disturbance that resulted in smoke coming from rear of set. What so you think the problem is? Bad board?
    Champion:
  • 203 Answers
I believe the problem with your TV is that it has one or more bad capacitors. I had a similar problem with my TV where it would power on and there was no picture. I took the back off of the TV and found that the two bad capacitors were bulging at the top. The capacitors provide power to the light bulbs. I bought two new, better quality capacitors and replaced the bad ones with them and the TV worked immediately. If you go to you tube you'll find videos that show step by step instructions on how to perform the replacement. All that you'll need are a soldering gun and solder and the new capacitors. I bought mine at digikey.com but you may be able to get them at Radio Shack. The capacitors have the model number on them.
Posted on Dec 02, 2014
Testimonial: "Thank you for responding. i removed the the back cover and didn't see any visible damage to any of the capacitors, but there is a slight whiny, high pitch, fluctuating sound coming from one individual capacitors. Could it be the culprit?"
  • 2 more comments
  • Christopher Thomas
    Christopher Thomas Dec 03, 2014
  • protector606 Dec 04, 2014
    Yes it could be the problem. One of the capacitors that I replaced was hard to tell that it was bad and the other was bulging badly so I replaced both to be sure.
    Here is a youtube video showing how to identify and replace bad capacitors on an LG TV.
    Add a Commehttps://www.youtube.com/watch?v=PWoz_-3OHIMnt
Polaroid 3211-tlxb have power and sound but no picture. It did smell like smoke. Any recommendations? Unit is 2 years old.
If you can see a picture (dim and low contrast) when you shine a light on the screen from an angle, your backlight inverter may have a burned-out part.
After this test, whichever result you get, unplug the set and use your eyes and nose to search for overheated parts. I have found connectors that overheated because of a poor-quality solder connection on the circuit board. Note that parts, particularly resistors, can overheat because of a fault in another part.
It is common for solder connections to deteriorate if they are frequently run at high temperatures. Sometimes circuit boards "normally" turn brown from heat because of marginal thermal design. Check the solder connections on components in the hot areas.
Static electricity precaution: most digital electronics are easily damaged by static electricity discharge. Avoid touching the metal parts of the circuitry unless you first touch the metal frame of the set to discharge any voltage buildup on your body.
Nov 10, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Tv won't turn on
I think its a defective convergence chip/circuit and need a tech to replace it. It could cost about $300 or so.
Nov 04, 2007 | JVC AV-56P575 56" Rear Projection...
Alba TV LCD4288DF 1080P Sound but no picture. On switching on get a very brief flash of the picture then screen goes blank, tried on all inputs with same results. It did sort its self out for a while but...
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Jan 20, 2011 | Televison & Video
HAVE A PANASONIC TC-20LA2 LOUD SOUND COMING FROM REAR OF TV AND NO PICTURE, ALSO A LIL SMOKE COMES FROM TOP VENTS AND SMELLS LIKE ELECTRICAL
That will be real expensive repair jobs, it can be from the power supply or from the backlight inverter circiuts. I would leave it unplugged.
It will cost too much to have it done at the repair shop, it is only 4:3 screen also. You may want to think about it first.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 26, 2010 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
When I plug in my 36" Zenith TV the screen stays black, a clicking and popping noise comes from the back and I smell acrid smoke like from an electrical fire. What is going on, and is it repairable?
Caution: Never power on the TV set again until this fault is retified.
It is anode arcing takes place inside the TV. Its final anod cap is arcing with neighboring surroundings. A smoke like fume along with a foulin smell will be there. It is repairable. Its Line Output Transformer [LOT] shoud be replaced with similar type and number. Before connecting the anode cap to the final anode of the picture tube, cleen the anode hole and surrounding area with some sort of cleaning solvent [we uses pure turpentine for that purpose], throughly, and wipe it out to dry out well.
Oct 16, 2010 | Zenith D32D51 32" TV
My tv is a 55pp9401 55 in rear projection tv
There do not appear to be any product alerts out for this television from the manufacturer.
Usually the problem you are describing is the result of damage to the television from electrical surges or accidental bumping of the tv. The problem is either power, tuning, or connections.
Check all connections to make sure none or loose, replace any connectors to the tv to see if this was the problem. If not the tv will require internal repair.
Jul 01, 2008 | Philips 55PP9363 55" Rear Projection...
Audio problem in our Sony TRV38 handycam..Please help!
I am not sure if you can use an external microphone on that model (check your owners manual) but that would be the first thing to try. If it records OK using an external mike, then the problem is with the internal microphone.
Mar 17, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Hitachi 57TWX20B powers on ( but no picture or sound)
f you had multiple power outages, i would contact the power company or/and insurance company and it should be covered under that, but sounds like power supply problem if you had power surges
if lighting cause it then it could be anything.
Feb 08, 2008 | Hitachi 57TWX20B 57" Rear Projection...
D52gw12 ge television smokes
Please give complete service # off back of set so I can research
with accuracy........T.
Sep 07, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
