Question about Ruud Central System Air Conditioner
Pilot lights but main burner doesn't come on. Just replaced the pilot safety switch but still didn't start.
Replaced White Rodgers Mercury flame sensor. Power sources appear to be working but main burner not igniting. Part # was 3098-134 & 3098-156.
    Problem Solver:
  • 43 Answers
Does the induced draft motor come on and does the pressure switch close? have you checked the roll out safeties?
Posted on Dec 03, 2014
  • Ralph Gilkison
    Ralph Gilkison Dec 03, 2014
    This is a ruud gas furnace, not a air conditioner.
  • ardvark02 Dec 03, 2014
    the induced draft motor is part of a furnace operation, it's operation should close a pressure switch proving air flow to the exhaust stack. It is not part of an air conditioners operation sequence.
Gas wall furnace pilot goes out when burner turns off.
When the main burner turns off, does it make a whoosh or pop? If so, this would be the issue causing the pilot to be disturbed. And have you tried to adjust the pilot/thermopile strength, if possible? A stronger pilot may help. Now if the main burner slowly goes out, and the pilot also slowly goes out, and also slow to ignite, and you've replaced about everything else, it may be the gas valve itself that has/is giving up. Gas is impure and causes a sticky residue. And if the main burner is "slow to act", this tells me the piston that's inside the valve is slowly opening or closing, and may be the reason the pilot is acting up. Make sure you check the outlet to your flue pipe also for obstructions. If the unit doesn't vent properly it can have more heat in the flue. That heat can have a downward rush when the burner goes out, kinda like forcing air through a clogged tube. And when you quit forcing the air, some of it comes back at you. Before condemning the valve try to check all else as you have done with the thermopile and such. Please work safe and I hope this helps.
Oct 09, 2017 | Williams Heating & Cooling
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Jul 30, 2012 | Imperial IFS40 Deep Fryer
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Just moved into this house, with a warnock hersey gas fire wh3990 removed the glass for cleaning now it won't come on .I think I disturbed the log placement ,it has a temperature control but even...
When you replaced the glass, you may have not made contact with the glass safety removal switch. In which case, other than the pilot, nothing else will work. When you cleaned the glass, I hope you didn't use a commercial glass cleaner. As they have ammonia in them and it leaves an invisible residue on the glass. When it heats up the residue will turn white and stay on the interior of the glass. If you did use a commercial glass cleaner, remove the glass (which you're going to have to do anyway) and clean it with a 50/50 solution of vinegar and water. Then dry the glass thoroughly with paper towels.
The glass safety removal switch is generally at the bottom of the firebox opening right under the glass, In fact the glass will rest on it. Once everything is cleaned (if necessary) and reassembled. Be sure that after the pilot is lit, the gas control knob is turned to ON. If you have a wall switch that tunrs the burner ON & Off, it will now take over.
Hope this helps you and thanks for choosing FixYa.
Sep 21, 2011 | Heating & Cooling
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Dec 10, 2009 | Heating & Cooling
Gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Nov 16, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Ruud Central System Air Conditioner Logo
57 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
