Question about Alesis DM-Dock USB/MIDI Drum Module for iPad
Please tell me the color code of the main cable jack to each individual pads
The 25 pin jack was replaced with an old printer jack which utelises the 25 pin jack.Iam using the color wires from the printer are they similar in comparison to the Alesis colors. The Alesis DM6 has 9 main Events meaning 8 x 2 cable wires plus an additional 3 for the snare pad this gives you a total of 19 wires.I am trying trial by error method.I have guessed the first three pads correctly eg Hi Hat control - Red /red White Hi - Hat - Green / Green White Tom3 - Blue / Blue White. As I am not familier with color codes of cables is there a standard one for Alesis DM6 AND IF SO WHAT IS IT.
SOURCE: Alesis Multimix 8 Audio driver wont load
the mixer does not work damn that stuff.
Posted on Jan 30, 2009
  • 5603 Answers
SOURCE: Ihave an Alesis D4 drum sampler.I have not used in
Some of the Alesis products have a setup and data memory backed up by a battery. It is POSSIBLE that your battery expired and took the sound memory with it.
Investigate if you have a battery in yours (buried in the guts) and check the voltage. It should be above about 3 volts.
If it is below that, replace the battery and find another unit to clone the data from.
Posted on Sep 24, 2009
  • 5603 Answers
SOURCE: cannot transfer beats from alesis sr16 to alesis
The sync signal that is sent on the MIDI cable is actually a "clock" of something like 96 ticks per measure. This is the "MIDI sync clock". This is a single byte FF hex.
The beats themselves are not sent. The firing of the individual percussions should be.
Posted on Dec 27, 2009
djlaplaya
  • 74 Answers
SOURCE: how do i dump midi user patterns from alesis sr 16
you may well have to go via a third unit, a computer or laptop to store the data then send it back to the other machine.
Posted on May 06, 2010
kevinmunn
SOURCE: clip signal on Alesis multimix 12 USB - no inputs!
What capacitors?
Posted on Sep 28, 2011
Good morning,perhaps I should elaberate a bit further upon my already sytated problem.
Try to find a replacement. If not have a service center with a schematic make a new one.
Dec 05, 2014 | Alesis Music
Tip
IPod Shuffle 2nd & 3rd gen Sync cable
save up to $50, make a sync cable for ipod shuffle 2nd gen and 3rd gen on your own,
all you need is a 4 poles 3.5 mm jack, and USB plug. you get this on an old USB connectors ,
the color coding of USB cables is in standard so all you have to do is to solder the color coded wire to the 3.5 mm jack
here are the links of pictures of wire color coding that tells where the wire shouuld be solder http://i863.photobucket.com/albums/ab192/matrix_jc2001/Untitled-1.jpg
on Dec 31, 2009 | Audio Players & Recorders
HI! I have one machine Toshiba C350 this is Color
Hello
The error code that is displaying, is the charger cleaner motor abnormality: Charger cleaner motor is not rotating or the wire cleaner is not moving normally.
Please try the following.
(1) Check if the main charger is installed normally.
(2) Check if the charger wire is broken.
(3)Check if any of the connector pins of the charger cleaner front/rear position detection switch is disconnected.
(4) Check if the cleaning pads are damaged or removed.
(5) Check if any of the connector pins of the charger cleaner motor is disconnected.
(6) Replace the charger cleaner motor.
(7) Replace the Logic board.
I hope this helps a bit
Regards
May 23, 2011 | Toshiba e-Studio 350 Copier
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
My dc7100 has a compact power supply with proprietary 24 pin plug. Pretty sure power supply is non-functional (shorted green to black and fan didn't come on). Is it possible to rewire a conventional ATX...
I just spotted this, hence the late solution. Perhaps this will help someone in the future.
Yes it is possible.
Observe the color code of the insulation of the wires.
1) Orange wires are 3.3 Volts
2) Red wires are 5 Volts
3) Yellow wires are 12 Volts
4) The Green wire is the Soft Power On wire
5) All Black wires are Ground wires. Doesn't matter which Black wire it is, it's a Ground wire.
(It isn't a Common wire. This is DC electricity, not AC)
These are your main voltages, and wires to be concerned with.
Fortunately all HP, (Or any proprietary computer manufacturer in that time period), did, was to change where the wires are placed in the 20, or 24-pin ATX main power cable connector.
They just moved the wires in the socket holes, didn't change the color code.
Solution is,
1) To remove the wires in the ATX power supply, main power cable connector
2) To remove the wires in the proprietary computer's ATX main power cable connector.
(NOTE*
BE SURE to make a concise, clear, drawing FIRST, of where the colors of the wires went in the proprietary connector, BEFORE you remove them!)
3) To reinstall the wires into the proprietary connector.
(Again. Following the color code of the wires you removed)
Removing the wires out of the 20, or 24-pin ATX main power cable connector:
Observe these photos, of a 20-pin ATX main power cable's connector. This procedure can be applied to a 24-pin ATX main power cable connector also. (Or a 20 + 4-pin ATX main power cable connector)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
(Also gives you information about the color code of the wires)
The middle photo shows you a view of the Front of the connector.
The photo to the right shows you the Back of the connector.
Where the wires go down into the connector is a Socket Hole.
At the end of each wire is a metal pin connector. A Male pin connector.
This metal pin connector is shaped like a tube on the end, and comes up to a square shape as you go up.
The square shape fits the square socket hole.
On one side of the square shape is a Tang. It's part of the square metal shape, and sticks out away from the square shape.
Resembles a barb on a fish hook.
In this crude illustration, let a small L represent the side of the square shape, and this forward slash - / represent the tang.
l/
This is an illustration from a manufacturer that supplies this type of metal Male pin connector,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002092166_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
A needle with the proper thickness so it won't bend, is inserted into the Front side of the socket hole, and is used to depress the Tang.
If you look down into the back of the connector, and into an individual socket hole with a bright light, and a magnifying glass, you will observe that the square socket hole has a small notch in one side.
This is where the tang slides down into.
It isn't easy to see from the front side.
The tang is depressed using the needle from the FRONT of the ATX main power cable connector, and the wire is removed from the Back side of the connector.
The metal pin connector's tube shape only goes up so far, then it turns into a square shape.
The socket hole in the connector is shaped to match. Tube shaped hole at the front of the connector, square shape coming on up to the back of the connector.
The square shape's corners, of the metal pin connector, keep it from coming out of the Front of the ATX main power cable connector.
The tang keeps the metal pin connector from coming out of the Back.
More information about the color code of the wires in an ATX main power cable connector, (Scroll towards the bottom of the page)
http://en.wikipedia.org/wiki/Computer_power_supply
Oct 16, 2009 | HP Compaq dc7100 PC Desktop
Pin for driver side door bottom hinge pin seems to have lost the bottom part of the pin, what is the easiest way to replace the pin?
door pins are available at dealer and part store
to change you have to remove the door from truck and change the pins
Jul 09, 2009 | 2002 Chevrolet Blazer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
How to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Dec 20, 2008 | BenQ PB6100 Multimedia Projector
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Input cable
Hi Eric, you can use Black Color Cable (1.8 m) with 3.5 mm Stereo Mini Jack x 1 pc,
1.8 m (6 ft.) Cable with RCA Pin Jack, and 8-pcs No Skid Pads or you contac support for your particular speakers, considering is a good brand, here, http://www.yamaha.co.jp/english/product/av/products/pc/m8.html
there you may found your cable.
Carl
Nov 05, 2007 | Yamaha YST-M8 Computer Speakers
Alesis DM-Dock USB/MIDI Drum Module for iPad Logo
69 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
