Question about Hotpoint RGB745 Gas Kitchen Range
How to adjust oven controll to the right temp.
Could you you show me how to adjust the control to the right temp that the stove shows?
    Sergeant:
  • Hotpoint Expert
  • 448 Answers
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Posted on Mar 24, 2015
4 Suggested Answers
  • 1456 Answers
SOURCE: HOTPOINT MODEL RB790SH1A STOVE/OVEN UNIT HAS
Hello
If both gas and power supplies are on, but the stove won't heat up,the ignitors need to be replaced
Getting the right ignitor requires only the oven model and ignitor part number. Installation is quick and takes little time, even for a novice.
Turn off the gas and power supply to the Hotpoint oven. Take out any oven racks, and remove the oven's bottom pan by removing its retention screws at the oven's rear. Also take out the flame spreader by first removing the wing nut that holds it in place.
Take out the ignitor's mounting screws, and then pull out the ignitor's connecting plug--by hand. Discard the old ignitor.
Place the new ignitor in position and push into the connecting plug. Then screw into place the mounting screws.
Turn on the power and gas to the oven. Turn on the oven, and check the ignitor: if it lights in 30 seconds or less, it is working fine. Turn off the oven, and replace the flame spreader, bottom pan and any oven racks.
Posted on Nov 18, 2010
  • 88 Answers
SOURCE: The oven will pre heat
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Posted on Aug 16, 2011
Testimonial: "Thank you. That is the issue for sure."
  • 257 Answers
SOURCE: refix the right temp from control to oven temp the controllis set for 350 but it shuts down at 325 how do you calibrate it through the control?
Go to the manufacture site search for manuals on their site for the oven you have... usually PDF format
Posted on Dec 02, 2014
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
When I try to turn on the oven he control panel shows a f3 code
F 3 CODE FOR WHIRL POOL IS (OPEN OVEN TEMP SENSOR . replace this sensor . this should correct problem ..
Dec 03, 2009 | Dryers
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Jul 13, 2009 | Kitchen Ranges
F1 on frigidaire stove
Most F1 codes for frigidaire state bad EOC (clock) but the temp sensor is the least expensive place too start.
Mar 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
174 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
