Why do i have no power to my sub
One day it had no power checked fuse on power cord and it was good sub is only a yr old
    Sergeant:
  • 250 Answers
What model do you have, maybe there's another fuse inside.
Posted on Dec 02, 2014
My powered sub is humming
Does the humming go away if the cable is plugged in but you wiggle it? May be a bad connection on the input jack.
Mar 22, 2013 | Klipsch Audio Players & Recorders
Controler and sub woofer no power
This previous diagnostic, isn't good, if you test and no continuity between the positive and negative terminals generally means a blown sub.
You won't always get scratching or distortion from a blown sub. Sometimes the voice coil just overheats and burns out like a fuse. In this case there will be no sound at all from the sub, because no power can flow through the voice coil. A continuity test between the positive and negative terminals will show no connection.
Hope this helps.
Jul 05, 2011 | Audio Players & Recorders
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
My mother has a Kenmore 500 Gas Dryer at least 15 yr. old. Model 110 660 501. It stopped working and shows no indication there is power. Is there a main fuse or reset switch I can look for? We don't...
it would pay to replace dryer if it is 15 yrs old a newer dryer would be more efficent. Check wires from wall and run them to control panel. Ther should be a relay between power cord and switch
Mar 05, 2010 | Kenmore 72062 Gas Dryer
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
Need to repair my HKTS 14 Harman Kardon Subwoofer
Since this is a power sub woofer, it may have an amplifier problem that would require professional service. Yoiu can start by checking the fuse. Make sure the sub woofer is not plugged into the wall when you check it. Some of these powered sub woofers have the fuse right on the panel where the cord goes into. It may have a round cap and you turn it and pull the fuse out. If the fuse is blackend or you can see that the filiment inside the fuse it broken, you can replace the fuse with the same rating of fuse. The rating is on the metal tab at one end of the fuse or may also be listed right next to the cap for the fuse holder. If the fuse is not accesable from the panel, you need to remove panel and look for it where the power cord comes into the panel. It will be right in line with the power cord. The panel for most sub woofers are normally held on by screws all the way around the panel. You should only need to take the outside screws (around the edge of panel) off of the panel. The inside screws hold on the circuit boards, connectorsm and transformer.
If you had given more information about the problem with your sub woofer I could have given you a better answer, but with the limited information given all I can suggest right now is to check the fuse. That is always a good starting point. If you give me more information I may be able to help you much more, I have repaired many powered sub woofers but not this model. Most are very similar and can be checked with minimal effort. You would need to have a multimeter to check almost everything else with the sub woofer. Let me know if you have a multimeter and are willing to check it further. Anything less than a "FixYa!" rating is really not a good rating, so please do not rate this solution until we have had a chance to communicate more about the problem. That way I will not be given a bad rating when I have not had a chance to actually help you yet since I can not tell you how to fix your problem without more information.
Dave
Oct 14, 2008 | Audio Players & Recorders
Bose lifestyle model 5 /Acoustimass 25 sub power problem
Open or leaking components will look OK but, may not function as designed. Rather than create more problems, please consider whether the unit is worth repairing by a pro/tech, if so, do so.
May 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Help with repair for LG 2055ST
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Dec 27, 2007 | LG LMV2055ST Microwave Oven
No power to subwoofer i already check every thing
Good day!!
Well, depending on the brand, or model, of your particular SPK, you can change your sub for another, if warranty you has.
another thing is check for inside fuse, may be is fried, but carefully open and see if your sub has a FUSE.
well, thats it! my friend
Dec 02, 2007 | Altec Lansing ACS 495 Computer Speakers
76 people viewed this question
 Grubhead
Grubhead
