Question about Kitchen Ranges
I followed the instructions for removing and cleaning the glass on the bottom drawer but know I cannot figure out how to remove the small door on top. I do not know what the model no is - I cannot fi
I have already cleaned the glass in the large oven by following the instructions on your site. Cannot figure out how to get off the small oven door
    Genius:
  • 1,554 Answers
Upload some dramatic photos of it
Posted on Dec 02, 2014
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
HOW TO CLEAN THE GLASS DOORS
Hello larryjkelly - This may or may not be specifically for you model, however below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side.
I. Lift out center clear glass from wool shield, this glass just lies onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc.
I do hope this proves to be helpful.
Feb 25, 2013 | Electrolux ICON Designer E30SO75ESS Oven
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Mar 15, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Hp 7400c haze on INSIDE of scanner glass
I figured this one out.
There is a language panel on the front (that tells you what each button does). The original instructions mentioned putting the panel on but not taking it off. If you use a small, thin screwdriver or thin, dull knife from underneath, you can work your way across the bottom edge, popping off the language panel. When you remove the panel you reveal three screws, one rather tiny one in the center toward the bottom, and two medium sized ones to the sides closer to the top. Slide the glass cover up and off. There are two more medium sized screws near the slots for the cover. Remove all five screws. The assembly with the glass comes right off, allowing you to clean both sides.
Dec 14, 2008 | HP Scanjet 7400c Flatbed Scanner
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Maytag electric range door handle (how to replace?)
The above solution is fine, but you don't have to remove the door.  Open the storage drawer for access to the trim screws (3) on the bottom of the door, remove the screws.  Have a helper hold the glass along the bottom. Take the three screws on the top of the door trim out.  Slide out the glass and put in a safe place.  Remove the four screws that hold the handle brackets in place, remove the handle (or tighten if loose). Install the new handle (one screw on each side).  Reinstall all parts in the reverse order of disassembly.  The entire job took less than 30 minutes.
May 01, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
