Question about Martin Yale Model 1217A Medium Duty AutoFolder PRE1217A
We have a huge paper jam in the Martin Yale 1217A paper folder. The Operating manual says to "insert a flat tipped screwdriver into the slot located in the shaft, just inside the small access hole on
So much paper jammed in it that I can't turn the manual wheel to feed it through.
Looks like fixya is out of business. ... all zeros in replies.
the zeros you see are "unanswered' questions, just like yours.
Mar 09, 2015 | Martin Yale 620RC Ream Cutter, Sheet...
Turn on and it hums, rollers don't move
It's jammed. UNPLUG IT. Take the top off and turn it upside down and pick the scraps out of the corrers. Put it back on and try running it, in BOTH directions. If there is a staple or paper clip in it, it will take more than one try to clear it.
Oct 05, 2009 | Martin Yale Office Equipment & Supplies
Spares requirement
Contact Martin Yale International Gmbh in Germany.
Put Martin Yale in your search engine.
Feb 20, 2008 | Intimus 385 se Shredder
Have a Yale 5000CC shredder that will not run.
This may indicate a jam not quite sure as I am not familiar with Yale machines but from description thats what it sounds like
Jan 18, 2008 | Martin Yale 5000 (Cross-Cut) Shredder
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Martin Yale Model 1217A Medium Duty AutoFolder PRE1217A Logo
53 people viewed this question
Top Martin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Martin Office Equipment and Supply Expert? Answer questions, earn points and help others
