How to rec a video
Wnat to record a video
    Sergeant:
  • 250 Answers
Hi ! What model of DVD or BlueRay device do you have ? Is it a recorder or just a player ? From what source do you want to record ? We need more information to help you better !
Posted on Dec 02, 2014
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
Check rec tab
A nice easy one. Eject your tape and look for the record lock on the cassette. It's usually a small plastic red tab which you slide to one side. The record will then work.
It's put there to stop you mistakingly record over the top of something you want to keep. Just make sure it's nor something you want to keep before recording over it :-)
Apr 10, 2010 | Panasonic Palmcorder PV-DV203 Mini DV...
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Video function
An easier way to do this is to just press the right-hand button on the round wheel surrounding the set button. This allows you to scroll through all the various record modes: Snapshot, Bestshot, Video, & Microphone.
Apr 02, 2009 | Casio Exilim EX-Z40 Digital Camera
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
