Question about Gladiator Refrigerators
Gladiator freezerator converted to regular frig 5 yrs ago but freezer is not getting cold enough. Also loud banging noise from the compressor during the winter months. thxs Mike
Freezing not getting cold enough and banging noise from compressor.
  • mikepe Dec 02, 2014
    Thanks the odd thing of the banging is if the garage temp goes below 55 degrees. But definitely I will pull the panel and check for being dirty. Appreciate your help !
    Novelist:
    Scholar:
  • 165 Answers
The first thing to investigate is the condenser coils to see if they are clean. If they are caked in dust and lint/dirt then they cannot shed the heat created when the compressor pressurizes the refrigerant gas. This is on the high (pressure) side of the system. the compressor pressurizes the gas and them it is cooled. Then it goes through an expansion valve resulting in the gas expanding and getting cold. this cold gas passes through coils inside the unit absorbing the eat inside and making the inside cold. So if the condenser coils are clogged up and cannot cool the gas then the machine will not work. the gas will return too hat to the compressor and it will be running really hot, perhaps knocking. Use a vacuum cleaner and a brush to remove the dust/dirt. lint etc. clogging the cooling fins and then see if the machine doesn't work better. after 5 years this sounds very likely to be the issue. It is quick and easy to do and costs you nothing. If it is not the problem then at least yu will not be paying a technician by the hour to try it first!
Posted on Dec 02, 2014
    Thanks I will check and clean, but still wondering why the banging happens in the winter when the gargage dips below 50 degrees and not in the summer. Again appreciate your help. !
  • 1314 Answers
SOURCE: Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
Posted on May 14, 2008
  • 1462 Answers
SOURCE: load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Posted on Nov 12, 2008
  • 1214 Answers
SOURCE: Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Posted on Jan 26, 2009
SOURCE: Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Posted on Feb 28, 2009
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
Gladiator freezerator loud noise
Loud noises means that the Freezerator is working like it should be. The defrost heater element is on and the noise from melting ice dropping off the coil located in the back of the refrigerator section.
Jun 01, 2014 | Gladiator Freezerator Top Freezer...
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Load noise coming from freezer
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud Banging Noise
May 14, 2008 | Hotpoint HTS18GBR
Oct 31, 2007 | Refrigerators
Refrigerators Logo
73 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
