Question about Miele Cooktops
I have a Miele KM440 ceramic hob which gives a continuous high pitched not for 5 minutes after it is turned on. It also see,s to be erratic when trying to turn hobs on.
SOURCE: Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
Posted on Sep 15, 2008
SOURCE: Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Posted on Jan 13, 2009
SOURCE: have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Posted on Sep 29, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
SOURCE: Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Posted on Apr 20, 2010
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Miele ceramic hob
I would check the incoming power. If you have the proper voltage, then your electronic module is the problem and would need to be replaced, or the hob is dirty where the control panel is and needs to be cleaned because it's not sensing that its being touched.
Feb 05, 2012 | Miele KM5816 25 in. Electric Cooktop
The electonic part need to be changed, I WOULD LIKE TO KNOW IF IT IS POSSIBLE AND HOW MUCH WILL COST?
its very expensive...much better to but a new one...ceramic hob with knob control not the touch control...
Jan 17, 2010 | Miele 30 in. KM443 Electric Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
Nov 23, 2008 | Miele 30 in. KM443 Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cooktops Logo
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
