Question about Kenmore Refrigerators
Where is the main electronic control board located in a Kenmore Elite Model #596.76253702 ?
Refrigerator will not defrost; I believe it is the electronic control board and want to replace it.
  • Kenmore Master
  • 744 Answers
Hello Mike;
My name is Peter. I am a retired field service refrigeration technician.
UNPLUG YOUR UNIT BEFORE STARTING ANY WORK!
Your defrost problem may be your control board but, that is not where I would start.
In answer to your question, your control board is in the top front of your freezer section. When changing the control board ground yourself by rubbing your hands on something steel. Static electricity will knock a control board out.
Where is the main electronic control board located - 25304309-iykvtnwbj1poqn502gcweelx-3-3.jpg
Part number 12784415 - $120.00
More likely your problem is your defrost heater. You check your defrost heater with a multi-meter. Set the meter to the lowest Ohm setting. Place one meter lead on one end of the heater connector and the other lead on the other end of the heater connector. If the meter reads '0' or OL or infinity the heater is bad. It should read something like 35 or greater Ohms.
Part number 12729128 - $47.00
When changing you defrost heater it is common practice to also change the Bi-meWhere is the main electronic control board located - 25304309-iykvtnwbj1poqn502gcweelx-3-15.jpguploads/images/25304309-iykvtnwbj1poqn502gcweelx-3-15.jpg" alt="25304309-iykvtnwbj1poqn502gcweelx-3-15.jpg" class="h_mi" />
Part number W10165425 - $26.00
Both of these components are located behind the back freezer wall.
This is a major task to change these components. Bottom freezers are not service friendly.
1.) Completely empty the freezer (Unplugged).
2.) Take off the freezer front door.
3.) Remove the ice maker assembly.
4.) With a screw driver pop off the thermostat cover plate in the back upper right.
5.) Unscrew the back cover.
6.) Remove the center air vent. This is held in with plastic tabs. with a screw driver pop up the center tab and the side tabs.
7.) Pull the back cover out. You will need to flex the cover to clear the side rails.
Unless you are really good with basic electrical and hand tools, I do not suggest you attempt this repair.
A local service company will charge you about $400.00 or more.
Posted on Dec 02, 2014
Need too know where is the timer located on my Kenmore refrigerator model number 596.66952401
I don't believe it has one, it operates off the controll board. Sorry to ask but what is the main problem with this unit?
Mar 08, 2016 | Kenmore Refrigerators
My refrigerator is dead internal light is on
Rare that someone post their model number, Thanks! I believe the most likely cause is the 2213473 or 2304099 Defrost Control Board The control board is located at location #4 in the photo=> HERE located inside the control panel in the upper fresh food section. I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | Kenmore Refrigerators
Where is the manual depfoster switch for the kenmore elite refrig with bottom freezer??
All defrost activity is managed by the unit's main control board. I don't believe there is a manual defrost switch.
Oct 08, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
Kemore Elite Model #106.74902401 Freezer is working although frost is forming , the refridgerator is not cooling properly and the side fans are not coming on . It isn't making any odd sounds .
In your refrigerators case I believe the Click Here=> 10674902401 Kenmore Refrigerator Parts in that photo you may need to click to enlarge depending on what type computer you use. Item number 4 is=> 2304146 Control Board this is a defrost control board found behind the controls just above the top shelf inside your fresh food section and behind the controls. Many times you may find burn marks that indicate that the board is defective. Always disconnect power to refrigerator before working with electrical parts. This is the most likely cause for your refrigerator not defrosting but only the first thing of three parts to examine. Click here=> Here you will see item Whirlpool Bi Metal and Defrost Components Photo behind the rear panel of your freezer rear panel. The defrost Thermostat is=> 4387503 Defrost Thermostat and=> 2315531 Defrost Heater Assembly To make things simple begin by looking over the Defrost Control Board first. Ask me questions and I will help you should you have any questions, Thanks, Sea Breeze
Jul 13, 2011 | Kenmore Top Freezer Refrigerator
Defrost freezer of kenmore elite refrigerator?
Other things that may help you:The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise til it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into a defrost.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus wont let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician.
If this helps you please rate me as high as you can and thank you for using fixya.l
Oct 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Aug 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How can i test the heater of a side by side elctronic refrigerator like kenmore and frigidaire, the electronic control board has no test switch
I'm absolutely no expert, but I just had a repair person come diagnose my Kenmore Elite control board as being bad. Rather than testing the board, he tested the other components related to my problem (fridge wasn't auto-defrosting), and since the other parts tested okay, he said it had to be my control board.
Aug 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator warm
this particular model has onlya defrost thermo and heater. the defrost timer is actually built into the electronic control.behind the kickplate there should be a tech sheet to aid in r\troubleshooting the unit.all are a little different but youll be able to go into the electronic control andtest the parts indivually. all you reallly need to do is "force a defrost" cycle.
if need be a continuity test can be preformed on the defrost thermostat( clipped onto the the top of the evaqporator coil) as well as the defrost heater which is also located in hte evap section ( its wrapped around the coil(u-shaped element) heater should also have continuity.
defrost thermo IS the MOST common issue with any defrost problem. heres a link to sears.com gives a location as well as part numbers if needed 35is thermo and 33 is the heater
Mar 28, 2008 | Kenmore 54602 / 54604 / 54609 Side by Side...
Refrigerators Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
