Question about Panasonic DMR-EZ47V DVD Recorder/VCR
My DVD player recorder stopped recognizing the remote other than to let me turn it on manually play tapes, dvd's, and record manually. All the display shows is RC2. I can change this to C3, Int1, Int2
I have tried holding the enter and 1-2 button down but nothing happens. I have also tried alternating between 1 or 2 while holding the enter button. This seems to produce the setup screen on the tv, but I have no way to manipulate the on screen items. The remote will not move up or down on the Aspect ratio so basically I can not do the setup routine, neither can I control the player. I believe it should most likely be on rC1. The universal remote I purchased will do the same as the real remote. How can I get the remote to work, or do a complete reset of the unit????
    Top Expert:
  • Panasonic Master
  • 74,482 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Dec 02, 2014
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
I cannot get it to record a vhs tape to a dvd. The vcr will play tapes and the dvd player will play dvds. I need some one to walk me through what buttons to push to record.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Dec 20, 2010 | Toshiba DVR610 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
No remote--how do I record a dvd
On the lower right side of my unit there are STOP - PLAY - RECORD buttons
for operation without a remote control.
Dec 13, 2008 | Panasonic PVD4744 DVD Player/VCR
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
142 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
