Question about Socket Home Security
Connect dvdr to tv aerial no picture on tv
Dvdr is sentient connected via vide input cable to tv socket in wall linked to pre existing camera
  • 842 Answers
If you go to DVDR with the cable, then you need a cable coming out of it to tv.
Posted on Dec 02, 2014
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
Manual left behind in Afghanistan
make sure yo have the leads connected correctly,after you connected an aerial lead from the box to the tv aerial input,make sure the box is switched on then tune the tv until you see a signal from the box (usually 35)if you do it through a video you may find its on the same frequency causing ghosting on the picture,in which case you will have to change the output frequency of the box or thee video
Feb 06, 2008 | Audio Players & Recorders
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Home Security Logo
62 people viewed this question
Top Socket Home Security Experts
ray gallant
carl blood sr
Are you a Socket Home Security Expert? Answer questions, earn points and help others
