Everytime I plug my 2yr old phillips 50 inch lcd into the socket[s] I blows the fuse ,any ideas
Changed the fuse few times and changed power supply
  • 3 Answers
Plz do check the connecting wire of your lcd. As is it not possible to blow down of fuse with just internal circuit damage because of the electronic protective equipment present in lcd. So the most probable reason is that there is a shot circuit in your connecting wire.
Posted on Dec 02, 2014
    Top Expert:
  • Televison & ... Master
  • 74,496 Answers
Short circuited component/s inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Lets try this again my 50 inc/. tv keeps blowing fyuse when i plug it in stays on for about 5 sec thren bloews the fuse
Since we are trying this again, let's conclude that your TV has suffered power supply failure, especially if the fuse blows almost immediately.
Jun 05, 2014 | Audio Technica Televison & Video
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
My 39 inch tv fuse blown constantly
Either a short or incorrect fuse being used--fuses have become specialized beyond amperage and voltage ratings--a lot are special fuses and or either a slow blow or even a thermal type fuse.
If not a fuse issue, look for a short in the power supply or wherever that fuse is located.
Dec 19, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Have a da555es stereo receiver. Fuses blow as soon as you plug it in to wall socket. Receiver is approx 10 yrs old and just started doing this. Any ideas?
If fuses blow out imediatelly its a sign that its something wrong in the imput area eg the power pcb or transformer pcb. try to see is there in its supply some electronical parts broken or some bad wire isolation.
Feb 18, 2010 | Sony STR-DA555ES
I have a 42 inch ILO Flat Screen TV that is only about 3 years old. I was watching it the other night and it just went dead on me. Any idea what happened and is it fixable?
sounds like an ic chip went out possibly a what is called a mosfet but can't be sure unless I saw it could always be a blown capacitor as well but not likely. I have a 42in philips lcd and it did the same thing I knew it was the power supply but when I looked at it there was no obvious problem after blowing a few fuses to isolate the problem by taking out all the ics and then putting them in one by one to see when the fuse blows i came to the conclusion that on ic the mosfet would blow the fuse i orderded the part online for like $7 including shipping replaced it and now everything is working like a charm. I live in oregon if for some reason you are as well I could always take a look at it for you.
Nov 21, 2009 | iLO 3200 32 in. LCD Television
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
The fuse keeps blowing out
you have defective power supply! you have shorted parts! like diode or regulator. replace the shorted regulator.
Oct 03, 2007 | iLO 3200 32 in. LCD Television
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
