Is this tech support?
The tv will not start up and stay on. it cycles power for as much as 30 minutes before staying on. In the meantime, the picture has lots of distortion when it is on. Once it stays on, there is not a problem until I shut it off again.
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 02, 2014
  • James M Castleberry
    James M Castleberry Dec 03, 2014
    I took the back off the tv and was expecting to see swollen or bulging capacitors like I havebeen reading about in this forum, but no. It looks liek new. Can it still be the power supply?
  • The Knight
    The Knight Dec 03, 2014
    Capacitors are meant for energy storage. Never think a bulged capacitor only can cause a power regulator section circuit problem. There are so many other components on it; as you can see. Each and every one of it has its own duty [working]; when the power is switched on. If any one among it fails, we can say that the power supply board [SMPS]; is faulty. It will be best to replace this board as card basis. Just understand; I'm not a newbee in this service field. I'm working in this field of electronic equipment service; since 1974; am 65 years old now; and does the same till too; without any difficulty. I hereby share my practical experience with you all. Never forget: [An Ounce of practical experience is more than a Ton of Theory]; in any field of service.
I have an LG 47LB5D LCD Tv that shuts off after approximately 30 minutes running time. It will cycle back on after a few minutes, so I assumed it was the power control board; replaced it but Tv still shuts...
It sounds as if the resistors on the board of the television are shot not much that can be done but replace all of the boards in the television you should try and aim fans into the vents on the television and see if its stays on for longer
Mar 05, 2011 | LG 47LB5D Television
Works fine 30 minutes then no picture
Q502 must be top-shelf , first-quality only = no generic.
Use RCA 237470 or Sony 8-729-035-75 Both are first quality,
but RCA much less expensive..............................T.
Please rate this solution......................
Note:Blow-up caused by bad connects in horizontal driver
circuitry.Therefore,save your good,used flyback!
Nov 13, 2007 | Sony KV-35S65 35" TV
My sony 52" keeps cutting
You may have bad power and your TV may be reacting to voltage drops or spikes. Is your TV powered through any kind of conditioner, surge supressor or filter? If not, you should consider getting one even if its only a $100 item. Stay away from standard or computer power strips though. Make sure it is not overheating and you have plenty of cooling space around the TV both to the sides and back, if it starts to overheat it will shut down. Or it could be a panel or internal board error. You'll need to get Sony tech to diagnose the problem. Are you getting any blinking lights when it shuts down? these are a code for the techs to let them know what to start looking at .
Jan 07, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
TV will only stay powered up around 30 minutes. After 30 minutes tv will only powqer back up after a 30 minute or so cooling period. When tv powers off light goes amber just as though it were physically...
Power supply board have intermitten problems,not sustancenig a constance power to the tv.The tv power up 30 mins within the time frame,the tv work than,yes?The power supply board,that the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Vizio VW46LFHDTV10A 46 in. LCD TV
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sony 36brx800 shuts off on own
As a TV tech the simple answer is no! If you were a well qualified electronics tech but just not used to TV's then the answer might be a very weak 'maybe' and that's if you had a TV tech talking you thru the whole process on the phone.
shutdown probs can be the power supply, bad solder joints, or also very likely the high voltage power supply. Meaning the area where the TV generates upwards of 30 thousand volts!! The set has overvoltage protection that makes sure that things don't completely fry, catch on fire etc.
Ya really need special training to avoid getting zapped with tazer like volts or worse! Sorry but safety says better stay out of this one!
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Toshiba MW20FM1 DVD section quits
am toshiba authorized servicer-have same model in shop for same problem-dvd board is defective-new board is about 290 from toshiba america parts-tv is actually made by orion with toshiba name stuck on outside-orion is junk-cost more than new set to fix-junk it and buy a panasonic-so far they still make their oun stuff
Mar 11, 2008 | Toshiba MW20FM1 20 in. Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
