The shut down button does not shut down
Click on shut down button
  • Henry Parker
    Henry Parker Dec 02, 2014
    Has nothing to do with speakers.....
  • 845 Answers
Hold button in for a few seconds, then if it will not shut down. Replace the switch. Good-Day!
Posted on Dec 02, 2014
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
Tip
Change the Sleep Button on the Start Menu to Shut Down
Want to shut down Vista with one click, instead of sleep.
Open Power Options in Control Panel
On the current plan your computer is running, click change plan settings
It will open Edit Plan Settings, find Change Advanced Power Settings and click on it.
Power Options will open, find the expandable tab that says Power Buttons and Lid, expand it.
Expand the tab that says Start Menu Power Button.
If you are running a laptop there will be two options, one for On Battery and one for Plugged in, click on the word sleep to open a pull down menu.
Click on the arrow, than Shut Down.
Click Apply and than okay. Close all Windows, Shut Down should be on the start menu instead of sleep
on Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Turn off windows 8
MY asus laptop not shut down, it's only shut down click hybenate mode why?
go to energy settings and find out the settings and change the behavior for the power button.
Apr 05, 2012 | ASUS Computers & Internet
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Button monitor problem
Disable all startup items. Click on Start> Run> Type msconfig then press enter. Click on the Start Up Tab the click on Disable All. Click close and restart your computer.
Your system should be starting up faster compared before.
Feb 08, 2009 | Dell Microsoft Windows XP Home Edition
Hp pavilion s3015 goes to sleep at startup and does not recover
Shut down the PC by manually powering it off by holding the power button in until it is off. Start the PC. Does it boot correctly? If so, turn off all the Vista power modes.
Click on Start and in the "Start Search" block type "Power". Click on "Power Options" which should show up above the Start Search area. Put the dot in "High Performance" then click on Change Plan Settings, Change Advanced Power Settings, Click on Power Buttons and Lid, Start Menu Power Button, Click on "sleep" to reveal the other settings - select "Shut Down", then "Apply" then "OK". Close all open windows and shut down the PC using the Start button. Note the power button icon is now RED not amber as before.
Run the PC in this mode and see if the same problem occurs. If so, you have a different problem.
Apex44
Jan 07, 2009 | Computers & Internet
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
54 people viewed this question
 Grubhead
Grubhead
