Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
Sonywega takes. 30 try's to come on
Tried the reset button combination. Does it hurt to leave it on 24/7
    Top Expert:
  • Sony Master
  • 74,630 Answers
The SMPS control cirlcuit [power supply regulator inside]; does not get the start voltage. This is a common fault to Sony TVs and related to some resistors at that circuit stage. Even though the cost of component is very less, locating the exact faulty one is a skilled work. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 03, 2014
I'm locked out of my 7inch tablet made by Digiland what can I do to unlock it I have tried the reset button but it takes me back to that home screen asking for my password help me
Please read through these procedures and try the power button combination. http://www.techadvisory.org/2013/03/forgot-your-tablets-password/
Also, perhaps pressing the power button and reset pin may work. Just remember to wait around 15 to 30 seconds to allow the circuitry to reset.
Good luck.
Feb 05, 2015 | Tablets & eReaders
Can you leave your Sony wega on 24/7
Dec 03, 2014 | Sony FD Trinitron WEGA KV-36FS120 36" TV
E3000 reset doesnt work
Did you try a 30-30-30 reset?
  1. Hold down the reset button for 30 seconds.
  2. Pull the power for 30 seconds whilst holding the reset button
  3. Plug in power and hold the reset button for another 30 seconds
(My finger usually hurts after holding that button for 1.5 minutes ;-) Look at your watch to not cut down on the time.
Let me know how that goes.
Aug 13, 2013 | Linksys E3000 Wireless Router
Have hooked up DIR-615. It says the network "dlink" requires a password. Is this predetermined if so how do I find it. I have tried my usuall computer passwords to no avail. Thanks
I assume you're talking about the wireless network, not the wired network.
This password is manually set, not predetermined. To know/change it you'll have to use a network cable to connect to the router instead of wireless.
Once connected, open up your browser to 192.168.0.1, this should bring up the router's web configuration page, from there:
- Login (by default: user: Admin, pw: <blank>
- select WIRELESS SETTINGS and press the "Manual Wireless Network Setup" button
- you should see the configured wireless password at the bottom under the "Wireless Security Mode" section.
if you failed to login with Admin/<blank> combination it means the password is changed previously, in this case, you must reset your router.
Quote from user manual, here's how to reset it:
"To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Good luck
Jun 13, 2012 | D-Link DIR-615 Wireless-N Router (54682G)
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
How can i reset the password to my wireless router (wr850G) I've held down the reset button for more then 30 sec on and off with no luck and when I try to log into the router through a wired connection...
Did you try unplugging it, holding the reset button for 30 seconds, then plugging it in (while holding the reset button), then (after I'd say like 5-10 seconds) letting go of the reset button? Also, if you're seeing a blank configuration page, it could be that the username/password combination is wrong. Try using username "admin" and password "password" "1234" "0000" "admin" and leaving the password blank. One of those combinations should work.
If none of those work, unfortunately, it might be that somehow the router got damaged or broken somehow. You can try some of the steps from the manual (located here) to get it to work again, but you might want to look into a new router.
Jun 16, 2011 | Arris WR850G Router (DHWR850G)
How to unlock the password
On the back it has a reset button (you may press it with a paperclip). Check the manual for how long you have to keep pressing it restore factory defaults and what will these be exactly (usually admin/password or no password at all).
Mar 01, 2011 | Computers & Internet
I have reset the WNDR3300 and used the disc to try to get a new password; however, a window keeps popping-up that wants my username and password. I tried every conceivable combination without any success....
Please try to reset the router with the reset button atleast 30 seconds depressed... And again unplug the power cable and plug the power cable by pressing the reset button n leave it after 30 secs..
and then again unplug the adapter cable n plug in n have the fun...
Thanks
Sep 20, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
No button will work except "cancel" button on model # GU1500XTLS1 Have tried all suggested troubleshooting tips in manual
I have the same problem. The only temporary solution I have so far is to turn off the circuit breaker and wait between 10 & 30 minutes before resetting the breaker. The the dishwasher will work for one cycle.
Aug 27, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
