Question about Garden
I have a 028 super sthil chainsaw I have replaced the carb.,fuel line and filter put in new cas mix,and checked firing is good.but saw will not start what is next step
I cannot get the saw to start, I have changed the fuel, fuel line, filter, carb, and checked and I am getting good fire
  • Eugene Rounds Dec 02, 2014
    Hi James Michael Pennington, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is the plug wet? if so have you checked spark arrestor screen and the compression? Most 2 cycles need at least 100 psi to start.
    Problem Solver:
  • 23 Answers
I am a little out of practice with the 028, but I do remember that they used to sometimes shear/break off the flywheel key, if ALL else fails, take off the flywheel and check the key. To stop the crankshaft turning when you are unscrewing the flywheel nut, jam a length of thick recoil cord down into the plug hole (remove plug first of course) while the piston is just before the top of its travel. Then revolve flywheel in an anticlockwise direction until it jams. Remove the cord afterwards!!!! and replace the plug.
Posted on Jan 02, 2015
  • James Maidment
    James Maidment Feb 02, 2015
    After the above steps insert the cord into the plughole again and remove the flywheel nut (13mm spanner or socket) and being very careful you can lever off the flywheel by putting a large (1/2" wide at least) screwdriver behind the magnet on the flywheel and against the crankcase (not the fins on the cylinder) and lever but not too hard and then revolve the flywheel 180 degrees (half a turn) and repeat the procedure still just trying to rock the flywheel a little. Keep doing this (revolving a half turn each time) until the flywheel loosens. It may take a number of times, but don't rush it. Eventually the flywheel will loosen be careful not to drop the flywheel key (a 1/4" long half moon shaped woodruff key) and then you can check the key to see if it is broken. Some of the 028's had integral keys moulded into the flywheel some had a separate key. If the key is broken, remove the bit that is in the crankshaft as well as the thin strip which is sheared off and replace the key (if the key is part of the flywheel then you will have to replace that too) and then replace the flywheel on the crankshaft.. Tighten the flywheel nut to 33Nm (24ft lbs) and reassemble the rest of the saw and try it out.
    Master:
  • 401 Answers
Check the obvious first, check the spark plug and check for fire from the coil, check the spark plug. Then check compression. You have to have good compression for these saws to run.
Posted on Dec 31, 2014
    New Friend:
  • 61 Answers
Sounds like trash on jets remove carb and clean and rebuild it
Posted on Dec 03, 2014
  • 17 Answers
SOURCE: Husqvarna 350 running problem
Pull off the exhaust, does the piston look ok?
If scored thats not good.
If ok check fuel filter , pressure test lines or remove and check for cracks. Just a start but check easy stuff 1st or get back to me with more info, cheers
Posted on Dec 28, 2008
Tinkertown
  • 16 Answers
SOURCE: wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Posted on Feb 16, 2009
johncaman
  • 201 Answers
SOURCE: Poulan saw will not start
This is not really a solution.... I can't post a comment. I think you know where I was going with the flywheel thing - whether or not the timing is right. I thought you'd pulled the flywheel yourself, and sorry, I'm not sure how to pull it. I'm assuming this is a 2 stroke motor... you might want to just check that the piston is near top dead center when the magnet on the flywheel hits the coil..... you can stick a pencil or anything long through the spark plug hole to give you an indication if the piston is at the top of the cylinder or not. Let me know how it goes!
Posted on Mar 14, 2009
  • 15 Answers
SOURCE: poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Posted on Nov 08, 2009
  • 4088 Answers
SOURCE: poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Posted on Feb 24, 2010
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
My stihl 028 super wood boss wont start
is it getting gas?is the fuel filter plugged?does it kick if you drop some fuel into the carb?
Mar 25, 2012 | Garden
Brand new PP4620AVX, filled it with gas,tried to start but no gas is getting to carb.
It's not getting fuel, either the fuel lines are plugged or they may be broken. Take off the air filter cover and the air filter. Check the fuel lines going into the carburator. Wiggle them a little, they may be broken and need to be replaced. Also check the fuel filter, use a 6-8", bend a hook on one end and fish out the filter from the fuel tank. It might be best to take the saw into a repair dealer if you can't figure how to get to the various parts on the saw.
Nov 28, 2011 | Poulan Pro Chain Saw 46cc 20"
I changed fuel filter ,fuel line to carberator ,rebuilt carberator and adjusted properly put new mixed fuel and coil is new and gets good spark motor has compression motor fires and stops runinng riteaway ...
Are you sure you pump in the unit properly? Some carbs have the gasket against the carb body and some have the pump next to the body. Also check the needle valve for proper operation,and dirt.
Jan 20, 2011 | Husqvarna Partner K1250 Cutoff Saw Air...
Working on sthil fs74 weedaeter. redoing carb need to know order of gaskets to double check myself. cant seem to get it going 100%.starts good but doesnt perform so well so decided to clean carb . replaced...
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands as well. Check the muffler for plugging due to carbon build-up. Check the carburetor to cylinder gaskets and heat insulator for damage or plugging of the impulse passage. The engine should 4-stroke lightly when running at speed unloaded, but immediately 2-stroke when trimming. Adjust the H jet needle somewhat to achieve this. Make sure the fuel mix is fresh and using chain saw oil only at 50:1 ratio. Make sure the lower chamber diaphragm in the carburetor is flexible with no holes or cracks. Hope this helps!
Aug 07, 2010 | Garden
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Stihl chainsaw 028 wb will not start it has spark, but always floods, I cleaned the air cleaner
Does the saw have a lot of hours on it ? What is the fuel mix you are using, Stihl recommend 40:1
You may need a CARB KIT.
Feb 02, 2010 | Garden
Wont run without choke being pulled out 1/4 .
INFO:
-Remove Carb and clean, you have a high speed fuel port clogged.
NOTE:
This would also be a good time to replace your fuel lines, Take photos before you start.
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
Jan 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
