Question about Garden
How do I set the magneto timing on a Toro Model 38050 snow blower
Tried different setting when bolting in the magneto
  • 2,760 Answers
All you need to set both points and mag spacing is a ole fashioned pack of matches , 1st remove matches from pack save one match , clean cut end!! with flywheel removed take out 5/32 screw on tin cover inside there will be points and condenser ,(if it's old model ) if not there will be a pick up coil and stator (finned lookin thing) take clean cut match Not the red end but the other end carefully move point arm away and put match in gap let arm go and slowly pull match out , use screw right next to it to adjust till match pulls out easyly with lil friction ! tighten all screws well install cover and screw for it , next obtain new aluminium shaft key , dont reuse old one , carefully install in key way and put flywheel down on shaft , tap once with a rubber mallet to seat it , install shaft nut and lock if it has one , unfold match pack all the way open hold with one hand in place where flywheel edge is flattest and carefully install magneto till it just rubs paper with a light skuff ,tighen all bolts well and install cover, start engine normally !! it should start right there if all your parts are good !! easy hah!!
Posted on Dec 12, 2014
2 Suggested Answers
SOURCE: How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Posted on Feb 09, 2014
I have a Toro 724 snow blower model 38050. It runs great. Everything works and turns. When I engage the drive and or the auger. It kills the engine like when I shut off the key. If I hold the safety...
Sounds like the safety switch is bad or needs resetting. I had a lawn tractor that did that and I disconnected the safety switch. I know you should not do this but I did not want to put more money into this machine. It does work ok without it.
Feb 18, 2018 | Toro Garden
No spark on Tora 724 snowblower, mod. 38050 Ser. 1004915, new pts set at 0.020, emptied old gas, add new gas, condenser, plug, new coil. is there a grounding problem that I missed? Air gap setting behine...
Ground is only for shutting of engine if it not hooked up wont turn off. Take flywheel off and look at magnet. Make sure it has not moved meaning they are glued in place and wont fall off. Give it a wiggle and see if it slides. If it does pull magnet off and re-glue in place. You will see mark on inside where it was originally.
Feb 19, 2015 | Toro Power Max 726 OE Snowblower - 37771
How do I set the Magneto timing on a toro 38050 snow blower
Use a .010 thousand feeler gauge ,or a business card if you don't have a gauge. Place between magnet on flywheel and magneto. Tighten magneto screws and you should be OK. If this doesn't start your machine check the shear key between your flywheel and crankshaft. If this shear key is dented as much as a hair, you could have starting problems. Let me know what you find. GOOD LUCK FRIEND.
Dec 02, 2014 | Toro Garden
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Toro 828 oxe blower shear pin
knock the broken one out with a punch and hammer put a new sheer pin you can make on with a bolt just grind down the middle of the bolt so it is thinner than the rest , I do this all the time
Dec 12, 2013 | Toro Power Max 828 OXE Snow Blower - 28...
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro 3650 snow blower paddles
I used a needle nose plyers to hold the nut. It still is dicey and a PITA-will let the dealer do it next time
Feb 28, 2010 | Garden
Toro self driven magneto setting
most any newer tecumseh or briggs will be .012 air gap setting
lawnboy is.010 setting
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
