Question about Saws
How do I fix a circular saw that runs, but the second it hits wood it stops the blade? The saw was used just a few hours. Looks almost new.
Asked the tool manager at home depot and he didn't know what the problem would be.
  • 71 Answers
Is the blade loose causing it to slip on the axle when it gets pressure from the wood? You should be able to just tighten the big bolt in the middle of the blade.
Posted on Dec 02, 2014
Testimonial: "No, the blade stops, no slipping. Thanks"
  • Ethan Marvick
    Ethan Marvick Dec 02, 2014
    I have herd of some saws coming with a clutch system to prevent kickback or damage if it gets pinched in the kerf. Try to make sure that the blade is on tight flat and not bent, warped, or installed backwards.
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
Wsc255 circular saw makes a whining noise when I start it up when I put the blade onto the wood the blade stops.
Either the motor is shot or the bearings are shot. Or both. You can buy replacement parts on eReplacementparts.com. It might be worth your time to just buy a new saw. Look on eBay.
Feb 04, 2014 | Hilti Saws
Can't get blade off circular saw as the lock just slips when I turn the blade ... So
use a block of wood to stop the blade, or use a socket and and impact wrench.
Nov 09, 2013 | Saws
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
My new dewalt circular 18v has very little power, fully charged, blade not dull
Are you generally an unlucky person? It sounds like you got the one in 5000 that comes with a bad-cell battery. Take it back and trade it. There is no fixing a bad cell battery.
Don
Feb 29, 2012 | Dewalt Saws
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
Why does my circular saw blade stop when it hits to wood?
Hello
Make sure its not on backwords.Also be sure the saftey arm is up when your going to cut.
May 25, 2011 | Craftsman Saws
When using saw the blade comes to a stop on its own thro wood
Does the motor continue to run? If so, the blade retaining bolt may not be tight enough. Most saws have a 'stop' pin which locks the drive during the blade tightening procedure. Make sure the blade is very sharp to reduce cutting effort. Hope this helps!
Feb 07, 2010 | Saws
Saws Logo
94 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
