I have a dual cd player and im trying to find out how i reset it
The parking brake on my xdvd8182 doesn't work, im thinking a broken wire. Ive tried the codes, grounding with a switch and hooking up to e brake
It is illegal and unsafe to watch the monitor while driving. I assume this is needed for an RV or something.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Feb 24, 2010 | Dual XDVD8182 Car DVD Player
CD player is not ejecting the disc. Is there a way to override and force an eject?
read in the manual and it may have a tiny reset hole that a paperclip could fit in .try and reset the deck that way then try the eject again
Nov 20, 2009 | Dual Electronics XDM6400 CD Player
American Audio Mcd-810 dual cd/mp3 player
i know its the tray belt.because,the same thing happened to me.my player would sometimes say error. or sometimes it would not read any cds.because,the tray would not close tightly.im shure its an easy fix.i did mine by my self.
May 31, 2009 | American Audio Mcd810 Dual Mp3 CD Player...
How do i fix the error 02 on my dual cd770 cd player
I have a Sony CDX-GT210. How do I set the time? Donna
Mar 31, 2009 | Dual XDMR-7700 CD Player
MY DUAL IN-DASH DVD WON'T LOAD ANY DVD OR CD.
OK so be said the player will not load the CD...how in the world is he going 2 clean the lens if the player won't load anything? I'm just sayin...
Feb 03, 2009 | Dual XDVD8181 Car Video Player
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Cd will not stay in deck
http://www.fixya.com/support/t892341-cd_wont_stay_in
http://www.fixya.com/ThreadView.aspx?prdid=0&thid=661664
More of the same.
Jun 13, 2008 | Dual XDVD8181 Car Video Player
37 people viewed this question
 Grubhead
Grubhead
