Question about Boating
My 1998 Freedom 25 Inverter/Charger suddenly stopped inverting. It has been working fine for many years. I replaced the large Potter and Brumfield Relays about six months ago which was the cause of di
Removed cover to identify if the relay coils were working, yes. On power input the "pass through" relay clicks in and it passes 220v to the board. On selecting charge, the lower relay clicks in and the charge happens as normal. I have measured on the two large bolts that connect the heat sink mounted transistors to the large transformer and get 3v AC It is possible that the generator put out up to 270 volts in a peak pulse, as I recently changed the generator controller board, and had to do the voltage stability adjustment, and while doing this there were fluctuations. I really need a schematic to try to sort this out.
2 Suggested Answers
helmut_eckar
SOURCE: Freedom 25 Inverter charger does not fully charge batteries
The secret is in the Fishball recipe!
Posted on Dec 16, 2012
My Xantrex freedom Marine 25 inverter cut-out trips
Call Tekris I used therm for a repair they are friendly reasonable and do excellent repairs Tel is 732 938 4996 Located in Farmingdale NJ.
Aug 14, 2017 | Xantrex Technology Heart Freedom 25...
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
I need a replacement comm board for a Xantrex Freedom Marine 25-12 Inverter/Charger. The battery temp sensor got shorted out and probably caused damage to the installed comm board.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Jul 03, 2010 | Xantrex Technology Heart Freedom 30...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Boating Logo
155 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
