Question about Garden
Is 40.1 the correct oil mixture for huskvara chain saw
  • 937 Answers
The owners manuals for all Husqvarna products in the US call for a 50:1 fuel ratio. That being said, there are lots of opinions out there... Some believe that extra oil is good protection and promotes longevity of the machine. Some of the confusion may come from the fact that Husky equipment is distributed world wide and some countries specify a more oily mix like 40:1 or even 33:1. A support person explained it to me that different countries have different grades and quality of fuel... If you don't mind a little more smoke and maybe shorter plug life a little extra oil won't hurt, but you may not get maximum power from the device.
Posted on Dec 02, 2014
Loringh
  • 185 Answers
SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
  • 10865 Answers
SOURCE: husqvarna 40 chain saw
This happens for two reasons. First of all, take off the chain and the bar and clean it all up as saw dust may be the culprit. The other reason is that some chain oils are too thick. you can thin it down a little bit by adding a little kerosene or gasoline.
Posted on Mar 18, 2009
  • 11 Answers
SOURCE: petrol to oil ratio McCULLOCH 55cc chain saw 2 stroke
25 to 1
Posted on Apr 07, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
SOURCE: what is the gas/oil mixture for poulan wild thing chain saw?
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Posted on Dec 10, 2009
Need to know oil mixture for older huskvara chain saw
"All Huskvarna 2 stroke products use a 50:1 ratio.."
https://www.youtube.com/watch?v=dsY8LRNDKKI
Dec 02, 2014 | Garden
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the right fuel oil mixture???
ok im not a mind reader ,,,so what chain saw is it???? il have a go at this one,,,,,
most chain saws take a 50 to 1 mix if there not very old,,,but thats not all of them,,,ok?
some run on 40 to 1 mix,,,,old chain saws run on 25 or 30 to 1 mix? and very old saws run on 10 to 1 mix,,,,now you see you did not help me not telling me which saw you have,,, did you?
if its a new saw to be safe run it on 40 to 1 oil mix its a two strok so if there is a little smoke then its getrting oil to the bearings so it wont seze up?
Dec 02, 2010 | Garden
No problem; using a borrowed Husqvarna 44-don't know fuel mixtures (if any). The chamber for "oil"-is that engine oil (if so, what do you recommend) or chain saw oil (if not, is there another...
The mix fuel mix is 40:1. Use Husqvarna 2 stroke oil not the cheap stuff on sale at car service stations. The chamber for oil is for chain oil which can be bought at most places that sell or hire machinery like chainsaws, lawnmowers etc.
Nov 14, 2010 | Husqvarna 44" Chainsaw Bar Fits Jonsered...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas to oil ratio for chainsaw
You will want to mix at a ratio of 40:1. that is 40 parts gas to 1 part 2-cycle oil.
Mar 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
