Question about Amana Kitchen Ranges
Oven heats up very slowly and does not reach the set temp
    New Friend:
    Problem Solver:
  • 3 Answers
There is an oven temp gauge you can get to check the temp, When you have that you can remove the dial from the oven and if you look at the back you should see either one or two small screws. If you loosen them you can reajust the setting. Also if it (The oven) seems to heat up to slow It could be the heat sensor, That is in the oven and looks like a long rod. You can investagte changing that out but that is a bit more work.
Posted on Dec 02, 2014
Whirlpool accubake RBS275PDB6 will not heat up to preset temp
I am assuming the lower element is not working well. Go ahead and replace it. But first , go turn your breaker off to the oven and then back on. Often times it can be tripped but not showing due to the other poles not being tripped. The lower element is the cheaper one also.
Feb 24, 2013 | Ovens
Only preheats doesn't reach temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Doesn't get to correct temp set.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Mar 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
Fault code f1 came on during a cleaning -
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
Dec 26, 2007 | Maytag MER5870 Electric Kitchen Range
Kitchen Ranges Logo
107 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
