PTC123D35ARDA SERVICE MANUAL
Need parts & service manual for my ac/heat unit
  • 937 Answers
Try this:
http://www.amana-ptac.com/Portals/3/PTAC/PDF/IO-PTAC2.pdf
Posted on Dec 02, 2014
Looking for parts list for a carrier 38RE030 AC
Request the information directly from Carrier.
Jun 15, 2017 | Carrier Heating & Cooling
Machine will not charge a system the tank is full the solenoid clicks but wont charge a system.
the solenoid is broken and it needs to be replaced, it also maybe a fuse with a relay unit all together in one unit. you will need a service manual,
www.manualsonline.com/
www.instructionsmanual.com/
www.manualsdir.com/
www.manualslib.com/
www.ask.com/
/mfg.name/make/model/service/manuals/dealers/parts/
Sep 18, 2015 | Mastercool 69788 Recovery/Recycle/Recharge...
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
When AC or Heat is turned on, it trips the breaker
Boyd, from what you have described, it sounds as if the heating element is overheating and rather than the overheating sensor turning it OFF like it should, your home's circuit breaker trips. Which is a good thing. According to the Service Manual for your model : The heating element contains a fuse link and a heater limit switch. The fuse link is in series with the power supply and will open and interrupt the power when the temperature reaches 161.6°F, or a short circuit occurs in the heating element. Once the fuse link separates, a new fuse link must be installed.
Keep in mind, if you have the 115 - 120 volt model, it will not provide heat, if the temperature is below 40 degrees outside.
For your benefit, should you have to call a service technician to service or repair your unit. I have included a link to the Service Manual, that you can download and print for future reference. The service person will greatly appreciate it.
http://www.ajmadison.com/ajmadison/itemdocs/Room_Air_Service_Manual.pdf
I hope all of this will help you to further troubleshoot and solve the problem. Please let me know, Thanks.
May 06, 2011 | Friedrich TwinTemp YS09J10 Air Conditioner
My 2004 Toyota 4 runner ac control light is blinking anf the manual says see dealer for service, the ac is not cooling , what does this indicate, does the unit need recharging ?
Try this website for resolving car problems by downloading a FREE service manual for your vehicle. This is not an owners manual but a factory mechcanic's manual.
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 2004 Toyota 4Runner
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
A/C starts, goes immediately to heat
Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
Hope this helps,
Jeff
Rate me please.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
